Web login Fail - Cisco 3750
leepeiwai
I can access to Cisco 3750 with SSH, but fail to login to web http with the same login.
I am able to get the login prompt, the login error I get is "The server at level_15_access requires a username and password."
Below is my switch config:
username admin privilege 15 secret 5 $1$xsdfajiwuoeirlkajsd
ip http server
ip http secure-server
ip sla enable reaction-alerts
line con 0
line vty 0 4
exec-timeout 0 0
login local
transport input ssh
line vty 5 15
login local
transport input ssh
end
cheers,
pei wai
sansarav720e
Dear Pei Wai
      you want to specify authentication method for your web access either to use local user database or TACACS if configured , configure aaa-new modela and excute this command
ip http authentication aaa
aaa authentication login default local
http://www.cisco.com/en/US/docs/ios/12_2/configfun/command/reference/frf005.html
Santhosh Sarav
HTH Regards Santhosh Saravanan
