STP Issue with Cisco 3560
nouman_nabi
I have configured my switch port gi0/1 with following config but when I run stp command it shows me port type p2p instead of p2p Edge
Goble commands
spanning-tree mode pvst
interface GigabitEthernet0/1
switchport access vlan 5
switchport mode access
spanning-tree portfast
interface GigabitEthernet0/8
Interface           Role Sts Cost      Prio.Nbr Type
Gi0/1               Desg FWD 5         128.1    P2p
Gi0/8              Desg FWD 5         128.8    P2p Edge
Please Help me what is wrong with it.
Nomi
Julio Carvajal
Hello Nouman,
Configuration looks good, can you take the configuration out and place it one more time to see if it makes a difference.
The switch should place the type as P2P Edge as soon as you enter the Spanning-tree porfast command
Also what happens if you add the spanning-tree porftast default on global configuration mode.
Julio Carvajal
Senior Network Security and Core Specialist
CCIE #42930, 2xCCNP, JNCIP-SEC
Fabio Francisco
This has been covered before. Please take a look at https://supportforums.cisco.com/thread/2155657
On top of that you have statically configured the port in access mode and the other is in dynamic disarable mode. it shouldn't make any difference but I just thought to point that out.
HTH,
Fabio
