what is NO IP UNREACHABLES?
Anand Narayana
Level 6
Level 6
what exactly the command "no ip unreachables" or "ip reachables" does?
mheusinger
Level 10
Level 10
this command will enable or disable the creation of ICMP unreachable messages. For all details have a look at the command reference:
http://www.cisco.com/en/US/products/ps6350/products_command_reference_chapter09186a0080446279.html#wp1186813
Hope this helps! Please use the rating system.
Regards, Martin
In addition to the above post i would like to add that a Cisco switch can generate automatically three types of ICMP messages: Host Unreachable, Redirect and Mask Reply. An attacker can use these messages to aid in mapping a network.
Hence these commands are generally disabled on the interface as a security policy.
HTH, rate if it does
Narayan
rtrafidlo73
It is worthwhile to understand the fundamentals before seeing how it is implemented:
ftp://ftp.rfc-editor.org/in-notes/rfc792.txt
