What is the difference between a C9200-Stack-Kit and a C9200L-Stack-Kit?
AWUWI
I have both types of stack kits but they have the same part numbers?
C9200-STACK V01
800-104767-01
Also is there any difference between C9200-STACK V01 and C9200-STACK V02?
Thank you in advance for your feedback.
15 Replies 15
I have done some research, it could very well be that both the L and the non-L kits are exactly the same. Which would be weird, since the L kit is more expensive.
I found the link below where an engineer is using them successfully. Another link where the kit is sold as compatible for both the 9200 and the 9200L models.
https://www.reddit.com/r/Cisco/comments/x75ewc/9200l_and_9200_stack_kits/
https://www.electroon.com/networks/accessories/cables-and-connectors/cisco-catalyst-9200-and-9200l-stack-module/?sl=en
