- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
03-08-2016 11:37 PM - edited 03-08-2019 04:53 AM
HI
I would like to know what is the Ideal value for CPU consumption and memory usages for cisco devices ?
any reference document/link will be helpful.
Solved! Go to Solution.
- Labels:
Other Switching
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
03-09-2016 12:01 AM
There is nothing like ideal value document for CPU consumption. It is all based on the customer network. But you should never see cpu going high on the devices.
for example we see for some customer that cpu utilization to be 30-40% on there 3750 switches which is expected.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
03-09-2016 12:20 AM
same for that. But u dont have the percentage value showing there. If the memory is getting utilized you would be seeing it on the logs.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
03-09-2016 12:01 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
03-09-2016 12:07 AM
What about the Memory consumption ?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
03-09-2016 12:20 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
03-09-2016 07:52 AM
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages wha2tsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
In the attachment, for ISRs, Cisco seems to recommend a max CPU not to average above 75%. Note, they do everything with their main CPU.
Switch CPU, generally shouldn't exceed 50%, because it shouldn't be doing data plane processing.
Memory is a bit more tricky, because much depends on how its being used because Cisco devices don't generally collect and rearrange free blocks. I.e. when you run out "bad" things happen, but you can run out while having sufficient free memory, just not enough in needed blocks. As a rough rule of thumb, you might want to avoid more than 75% memory utilization.
