What is the right IOS for a 2811 with Voice
tyoungbauer
I have 3 new 2811 routers and the current code 12.3.8 seems to have an issue not recognizing the MFT T1 controller card. So I went up to 12.4 code which seems to hav a new issue that every thing you access the web interface it reboots the router. Can anyone help to determine the right IOS for a 2811 with CCME and a NM-CUE and a MFT card running on GD code.
spremkumar
Level 9
Level 9
Both Software Advisor and Feature Navigator tool available out here CCO will come handy in deciding the ios file which needs to be loaded onto your box to support your requirements and the hardware.
Feature Navigator :
http://tools.cisco.com/ITDIT/CFN/jsp/index.jsp
Software Advisor :
http://tools.cisco.com/Support/Fusion/index.do
regds
I dont think there is GD image available for the 12.4 code
you should be good to go with 12.4.11T2 Advance IP services or IP voice feature set
Narayan
