Bookmark
Subscribe
925
Which 3650 switch is it?
KMNRuser
I am getting ready to update the IOS version on our production switch.
When i do a "sho ver" command and look at the hardware, it tells me it is a model "WS-C3650-24PD" switch.
Then i navigate to software.cisco.com.
I put in "3650" and i get the following options:
Catalyst 3650-24PD-E
Catalyst 3650-24PD-L
Catalyst 3650-24PD-S
I am not sure which of those 3 options the switch is as it does not show me this information in the "sho ver" command.
How can i tell which one it is?  i want to make sure i download the correct image..
Kevin
 Look at the IOS file. You will see that they use the same file.
cat3k_caa-universalk9.16.12.07.SPA.bin
which means, the L, S and E does not use different IOS.
Reza Sharifi
The same IOS works on all different models of the 3650 series.
balaji.bandi
L - Lan base
S - IP base
E - Ip services
Depending on the License you have purchased you can activate the features.
Cisco has changed the IOS image recently - they are the universal images for the models. you activate based on the requirement.
 show version ( give us what version you running) - make sure you read the release notes before you upgrade. and understand any caveats.
BB
