Which access switch model 2019?
wcoxy
Frequent Visitor
Frequent Visitor
I need to identify an access switch model with the following specs:
POE
48 ports
2-4 SFP / SFP+ ports
Lanbase software
We currently have Catalyst 2960s, but I can see that these are EOL now.
Could anyone advise on newer models that are similar please?
5 Replies 5
Reza Sharifi
The 3650 series switches are pretty solid. If you want to go with a newer model, 9300 is also available and the latest.
See data sheets:
https://www.cisco.com/c/en/us/products/collateral/switches/catalyst-3650-series-switches/data_sheet-c78-729449.html
9300
https://www.cisco.com/c/en/us/products/collateral/switches/catalyst-9300-series-switches/data_sheet-c78-738977.html
Deepak Kumar
We can use the Cisco Switch Selector to identify the correct and suitable model number for the same:
https://www.cisco.com/c/en/us/products/switches/switch-selector.html?guide=enterprise-e|upgrade-e|accesslist-e|2960-c-e
I think 3560 or 9200 series models are the best choice for you.
Deepak Kumar
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
balaji.bandi
if it is pure L2, i would suggest for longer and good investment protection Cat 9200.
BB
Leo Laohoo
I'd like to recommend 2960S but it's no longer available.
Eric_Braxton
Frequent Visitor
Frequent Visitor
I'd recommend the C9300-48 series.
