Which set of switches would be best?
dinesh2001
Hello and Merry Christmas,
I'm trying to decide on which pair or set of switches would be best? I have the following requirements:
I need approximately 150 * 100M ports
Approximately 150 * 1G ports
And a mix of both copper and fibre.
Could someone suggest a few suitable switch solutions? Maybe
a) set of catalyst switches which i can stack together, maybe something better than Cisco 3750
b) switches in the 6509 range and suitable line cards.
c) maybe a nexus suggestion, like Nexus 5K with 2K fabric extenders for increasing port density
I appreciate all your suggestions...
Thank you and regards,
DP
I would take a close look at the Catalyst 6800 which is the successor of the Catalyst 6500:
Or for a smaller budget, a "core" of n*3850 and access of n*2960-X should be also a quite powerful solution.
