switch 3750x not support ip routing command
_Ratha_
Level 3
Level 3
Dear all,
I have problem with Switch 3750x, with intervlan configuration, while I try to enter command:
switch(config)ip routing
it show invalid message.
switch(config-if)no switchport
it so message inject with this command. what is problem it is a new switch without previous configuration.
There you are then - LAN Base = layer 2 only.
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3750x_3560x/software/release/12-2_55_se/configuration/guide/3750xscg/swiprout.html#pgfId-1027804
You can use the 'license' commands to activate and evaluation IP Services license, or buy an IP Base or Services license for the switch...
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
10 Replies 10
Aaron Harrison
Please post 'show version'
CoreS1#show ver
CoreS1#show version
Cisco IOS Software, C3750E Software (C3750E-UNIVERSALK9-M), Version 12.2(55)SE5,        RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Thu 09-Feb-12 18:14 by prod_rel_team
Image text-base: 0x00003000, data-base: 0x02800000
ROM: Bootstrap program is C3750E boot loader
BOOTLDR: C3750E Boot Loader (C3750X-HBOOT-M) Version 12.2(58r)SE1, RELEASE SOFTW        ARE (fc1)
CoreS1 uptime is 3 minutes
System image file is "flash:/c3750e-universalk9-mz.122-55.SE5/c3750e-universalk9        -mz.122-55.SE5.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
License Level: lanbase
License Type: Permanent
Next reload license Level: lanbase
cisco WS-C3750X-24 (PowerPC405) processor (revision A0) with 262144K bytes of memory.
Processor board ID FDO1827P037
Last reset from power-on
3 Virtual Ethernet interfaces
1 FastEthernet interface
28 Gigabit Ethernet interfaces
2 Ten Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address       : 58:F3:9C:1B:73:00
Motherboard assembly number     : 73-12530-11
Motherboard serial number       : FDO182604V9
Model revision number           : A0
Motherboard revision number     : A0
Model number                    : WS-C3750X-24T-L
Daughterboard assembly number   : 800-32727-03
Daughterboard serial number     : FDO182616NC
System serial number            : FDO1827P037
Top Assembly Part Number        : 800-31327-09
Top Assembly Revision Number    : C0
Version ID                      : V06
CLEI Code Number                : CMMPM00DRA
Hardware Board Revision Number  : 0x05
Switch Ports Model              SW Version            SW Image
*    1 30    WS-C3750X-24       12.2(55)SE5           C3750E-UNIVERSALK9-M
Configuration register is 0xF
CoreS1#show license
Index 1 Feature: ipservices
        Period left: 8  weeks 4  days
        License Type: Evaluation
        License State: Active, Not in Use, EULA not accepted
        License Priority: None
        License Count: Non-Counted
Index 2 Feature: ipbase
        Period left: 0  minute  0  second
Index 3 Feature: lanbase
        Period left: Life time
        License State: Active, In Use
        License Priority: Medium
Aaron
Try this
Switch# show sdm prefer
  The current template is "desktop default" template.
  The selected template optimizes the resources in
  the switch to support this level of features for
  8 routed interfaces and 1024 VLANs.
  number of unicast mac addresses:             6K
  number of igmp groups + multicast routes:    1K
  number of unicast routes:                    8K
  number of directly connected hosts:          6K
  number of indirect routes:                   2K
  number of policy based routing aces:         0
  number of qos aces:                          512
  number of security aces:                     1K
This example shows how to configure a switch with the routing template.
Switch(config)# sdm prefer routing
Switch(config)# end
Switch# wr mem
Switch# reload
Proceed with reload? [confirm]
Now check once-if it works
Please rate useful answer
Joseph W. Doherty
What's the current SDM profile and the feature license (i.e. LANBase, IPBase, IPServices)?
CoreS1#show ver
CoreS1#show version
export@cisco.com.
Version ID                      : V06
CoreS1#show license
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
As also already noted by Aaron, you're issue is your LANBase license, which doesn't support routing.
BTW, would also recommend you migrate from (55)SE5 to (55)SE9.
InayathUlla Sharieff
You need to change the SDM template to routing.
mohseen patel
Level 2
Level 2
Apart from checking current SDM mode your switch is running also need to check license and IOS running for feature set.
Br.
Mohseen Patel
CoreS1#show ver
CoreS1#show version
export@cisco.com.
Version ID                      : V06
CoreS1#show license
