Why does my 3550 keep trying to use TFTP?
miketta89
I erased the config and the vlan.dat file and I'm now configuring the switch and it keeps trying to tftp and pickup a conifg from somewhere else. How do I stop it from doing this and why is it doing this?
I have saved the config and reloaded it and yet it still continues to look for a config.
3550_TOP#sh run
Building configuration...
Current configuration : 2272 bytes
version 12.2
service config
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname 3550_TOP
no aaa new-model
ip subnet-zero
no file verify auto
spanning-tree mode pvst
--More--
00:04:47: %SYS-5-CONFIG_I: Configured from console by console
vlan internal allocation policy ascending
interface FastEthernet0/1
no switchport
ip address 10.1.1.2 255.255.255.0
interface FastEthernet0/2
switchport mode dynamic desirable
interface FastEthernet0/3
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
--More--
%Error opening tftp://255.255.255.255/3550_top.cfg (Timed out)
00:04:59: %SYS-4-CONFIG_RESOLVE_FAILURE: System config parse from (tftp://255.255.255.255/355
0_top.cfg) failed
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
interface GigabitEthernet0/1
interface GigabitEthernet0/2
interface Vlan1
interface Vlan69
ip address 192.168.69.11 255.255.255.0
ip classless
ip http server
ip http secure-server
control-plane
line con 0
logging synchronous
line vty 0 4
login
line vty 5 15
login
end
3550_TOP#
%Error opening tftp://255.255.255.255/network-confg (Timed out)
00:05:21: %SYS-4-CONFIG_RESOLVE_FAILURE: System config parse from (tftp://255.255.255.255/net
work-confg) failed
3550_TOP#
%Error opening tftp://255.255.255.255/cisconet.cfg (Timed out)
00:05:59: %SYS-4-CONFIG_RESOLVE_FAILURE: System config parse from (tftp://255.255.255.255/cis
conet.cfg) failed
3550_TOP#
%Error opening tftp://255.255.255.255/3550_top-confg (Timed out)
00:06:37: %SYS-4-CONFIG_RESOLVE_FAILURE: System config parse from (tftp://255.255.255.255/355
0_top-confg) failed
3550_TOP#
00:07:15: %SYS-4-CONFIG_RESOLVE_FAILURE: System config parse from (tftp://255.255.255.255/355
0_top.cfg) failed
3550_TOP#
Michael
That behavior is caused by the command service config. To stop it attempting to load the config from somewhere issue the global config command: no service config
Rick
Rick
Edison Ortiz
Please post the output from typing show boot
Understand show boot behavior at :
http://www.cisco.com/en/US/docs/switches/lan/catalyst3560/software/release/12.2_37_se/command/reference/cli2.html#wp1937218
HTH,
__
Edison.
Michael
Rick
Rick
Perfect thanks, I was wondering what that was. Odd that its the default behavior after erasing the config.
Thanks again!
Michael
In my experience service config sometimes shows up when the config has been erased and sometimes it does not.
I am glad that my answer helped you to resolve your issue. Thank you for using the rating system to indicate that your issue was resolved (and thanks for the rating). It makes the forum more useful when people can read about an issue and can know that they will see the answer that successfully resolved the issue.
The forum is an excellent place to learn about Cisco networking. I encourage you to continue your participation in the forum.
Rick
Rick
