WIC-1DSU-T1-V2 does not show up on Cisco 2610
gentianhila
We have a Cisco 2610 router which only handles one T1 right now. We wanted to add a second T1. So we got a new card WIC-1DSU-T1-V2 and plugged that in W1 slot.
When I run show diag I can see the card but it does not appear on the running configuration.
The other card: WIC-1DSU-T1 right now it is working just fine.
How can I use the WIC-1DSU-T1-V2 on this router?
Here it is what I get
gw#show version
IOS (tm) C2600 Software (C2600-IO3-M), Version 12.3(5f), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2005 by cisco Systems, Inc.
Compiled Fri 12-Aug-05 13:29 by ssearch
Image text-base: 0x80008098, data-base: 0x80D239EC
ROM: System Bootstrap, Version 11.3(2)XA4, RELEASE SOFTWARE (fc1)
gw uptime is 1 hour, 24 minutes
System returned to ROM by reload
System restarted at 12:33:13 EST Mon Feb 18 2008
System image file is "flash:c2600-io3-mz.123-5f.bin"
cisco 2610 (MPC860) processor (revision 0x202) with 61440K/4096K bytes of memory
Processor board ID JAB032000AT (601560906)
M860 processor: part number 0, mask 49
Bridging software.
X.25 software, Version 3.0.0.
2 Ethernet/IEEE 802.3 interface(s)
1 Serial network interface(s)
32K bytes of non-volatile configuration memory.
8192K bytes of processor board System flash (Read/Write)
gw#show diag
Slot 0:
C2610 1E Mainboard Port adapter, 3 ports
Port adapter is analyzed
Port adapter insertion time unknown
EEPROM contents at hardware discovery:
Hardware Revision : 2.2
PCB Serial Number : JAB032000AT (601560906)
Part Number : 73-2839-12
RMA History : 00
RMA Number : 0-0-0-0
Board Revision : A0
Deviation Number : 0-0
EEPROM format version 4
EEPROM contents (hex):
WIC Slot 0:
FT1 BT8360
Hardware revision 1.3 Board revision C0
Serial number 16814057 Part number 800-03279-03
Test history 0x0 RMA number 00-00-00
Connector type Wan Module
EEPROM format version 2
0x20: 02 11 01 03 01 00 8F E9 50 0C CF 03 00 00 00 00
0x30: 60 00 00 00 99 10 29 01 FF FF FF FF FF FF FF FF
WIC Slot 1:
FT1 PMC4351
Hardware Revision : 1.2
PCB Serial Number : FOC11491PSV
Part Number : 73-8346-05
Board Revision : A0
RMA Test History : 00
RMA History : 00
Product (FRU) Number : WIC-1DSU-T1-V2
Top Assy. Part Number : 800-22193-03
CLEI Code : IPUIAPRRAA
Slot 1:
Ethernet Port adapter, 1 port
Hardware revision 1.1 Board revision F0
Serial number 27264352 Part number 800-02026-03
FRU Part Number: NM-1E=
EEPROM format version 1
gw#show running-conf
interface Ethernet0/0
half-duplex
no keepalive
interface Serial0/0
ip address 64.148.137.78 255.255.255.252
ip access-group 105 in
fair-queue 64 256 0
service-module t1 timeslots 1-23
interface Ethernet1/0
description "Connected to Internal LAN"
ip address 10.10.10.1 255.255.255.0
half-duplex
no keepalive
8 Replies 8
JORGE RODRIGUEZ
Level 10
Level 10
See end of table 4 - (Table 4 Platform Support for Cisco Interface Cards)
1.Supported on Cisco 2600XM and Cisco 2691 routers only.
http://www.cisco.com/en/US/docs/routers/access/interfaces/installation/guide/oview_ic.html#wpxref1129153
Not sure if you can get this to work on a non XM.
Rgds
Jorge
Jorge Rodriguez
But why it would be recognized as a card at all in show diag?
Richard Burts
Gentian
After looking at some of the Cisco documentation I believe that the WIC-1DSU-T1-V2 is supported on 2600XM routers but not on the earlier 2600 routers. I am not sure that there is any way that you will be able to use that card in that router.
Here is a link to one of those documents:
http://www.cisco.com/en/US/products/hw/modules/ps2641/products_module_installation_guide_chapter09186a008007cb95.html#wp1129978
Rick
Rick
Edison Ortiz
Strange, it should've picked up. Try configuring the controller manually:
http://www.cisco.com/univercd/cc/td/doc/product/software/ios124/124cr/hif_r/int_a1h.htm#wp1203419
HTH,
__
Edison.
Even though the docs states one thing, software advisory tools find software compatible with hardware the T1 v2 card is listed for the non XM 2610 router.. so you may be able to get it working either by Edison's suggestion or different IOS code.
Jorge Rodriguez
I will give it a try
When I read the original post and before I had dug into the question very much I had wondered about whether configuration of the controller was necessary and might be the solution. In the docs that I read through for WIC-1DSU-T1 and WIC-1DSU-T1-V2 they do not show any separate configuration of the controller. I am not optimistic that this will solve the problem.
The docs for WIC-1DSU-T1-V2 indicate that it was supported in 12.3 mainline code. And the code that you are running is a bit into the 12.3 series. You could try a more recent version of code and perhaps support was extended in later versions. It might be worth a try, but I am not optimistic that this will solve your problem either.
Rick
Rick
vaisharm
WIC-1DSU-T1-V2 is *not* supported on 2610 (non XM). Even though you see it in show diag, no matter what IOS you try, it would still not show the interface in show version or the running config.
(Also, no special configuration is required on the platforms where its supported.)
-Vaibhav
