wireless design
Hisoma Sama
Level 2
Level 2
hello team
I have routed access layer ( Core - distribution - Access )
i plan to install the WLC in the main site and some of the AP on different sites can the WLC discover the AP through the IGP routing?
thanks
balaji.bandi
High level  - Sure as Long as Underlay AP IP reachable WLC can see the AP and able to provision.
Your setup standard most of the deployment.
WLC connected to CORE Switch  - Access switch where AP are connected with PoE, with DHCP option 43 the AP discovers WLC and Join to WLC.
make sense ?
BB
make it discover through the DHCP op.
AP will get IP and IP of WLC and send discovery as unicast to WLC even if it in other site.
