03-13-2012 11:01 PM - edited 03-07-2019 05:32 AM
Is there any issue in writing logs to the router flash. Is there any possibility of getting the flash corrupted due to continious writing of logs to flash.
Raj
03-14-2012 01:36 AM
Not really.
03-14-2012 05:51 AM
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
My understanding is some flash technologies do wear out, i.e. they support only so many rewrites. However, except in the cases of solid state disks, it would be unlikely you'll doing enough rewrites to hit such physical limits.
03-14-2012 07:58 AM
So it is advisible or not to write logs to cisco router flash cards.
Raj
03-14-2012 09:47 AM
Disclaimer
Posting
Assuming I'm correct in my understanding of some flash technologies, the answer would depend on how often the same part of flash will be rewritten. I recall (?) we might be dealing with thousands to tens of thousands rewrites before the flash is adversely impacted. So, whether its advisable or not depends on the flash technology and how often the exact same location of flash is rewritten.
