WS-C2960-24TC-S Faulty Fan
jay3
I have a WS-C2960-24TC-S switch which is reporting a faulty fan under "show env all". Is it possible to replace the fan or power supply or do I need a total switch replacement?
Reza Sharifi
The 2960 series switches come with a built-in fan which is internal and not external. Also, the PSU is not modular. So, you can't just replace the fan. You would have to RMA the switch.
