WS-C2960s Port-based with radius 802.1x
gboliveira
Hello Team
I'am trying to apply the port-based configuration with Radius NPS on Windows Server and not luck yet...
I've seen some guides and everything seems to be ok, anyway, not able to authenticate...
Going to show part of my config:
aaa new-model
aaa group server radius port-based
   server name GOLDSRVDC02
dot1x system-auth-control
interface GigabitEthernet1/0/13
  switchport access vlan 10
  switchport mode access
  authentication port-control auto
  dot1x pae authenticator
  spanning-tree portfast
radius server GOLDSRVDC02
   address ipv4 10.10.30.24 auth-port 1812 acct-port 1813
   key mactest123
Going to attach logs from this switch:
I've tried also collect logs from NPS but couldn't find anything
Perhaps you guys could help me =D
balaji.bandi
how is the client authentication side setup ? and what client is this ?
check below config suggestion on NPS
https://integratingit.wordpress.com/2011/11/17/configuring-cisco-switch-dot1x-authentication-with-windows-nps-radius/
BB
balaji.bandi
BB
gboliveira
Hello Balaji, thanks for fast reply.
We tried to run this configuration again, but not success yet.
As per I see on EventViewer windows there is no logs related to dot1x solicitations.
Going to try do it again, maybe on another server.
gboliveira
We are able to fix this problem on dot1x auth after change the requirements from "domain computers" to another group that was created and assigned for users. A Microsoft guy helped me with this troubleshoot and we made it. Next step it to assign dynamic vlans for those authentications.
Best Regards,
