WS-C3560-8PC-S routing performance and capability
yuhuiyao
All,
What is the routing performance of WS-C3560-8PC-S? Can I get 100Mbps out of the interface?
You are right, but you can take the information provided on this page:
http://www.cisco.com/en/US/products/hw/switches/ps5528/prod_models_comparison.html
and come up with the numbers from the previous page.
Based on the page above, the 8port switch produces 2.7 Mpps which based on my calculations taken from the 2 models listed in the initial link rates about 3.6Gbps..
10 Replies 10
Mohamad Qayoom
Level 3
Level 3
I believe catalyst 3560 switches are going to reach End-of-life very soon.
Here is a link:
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps5528/eol_c51_519208.html
Mohamad
Mohamad,
That's incorrect !
The link you've posted is related to the Advanced IP Services feature set, not the hardware itself.
__
Edison.
Agreed. Mohadmad is not correct.
My bad, I am sorry.
Edison Ortiz
You sure can, please visit this link:
http://www.cisco.com/web/partners/tools/quickreference/index.html
and select any of the documents under 'Switch Performance'.
HTH,
__
Edison.
I have read that before. It did not mention any performance about routing. I am wondering if routing can have the same performance as swtiching.
See the column L2/L3 ? 3560 indicates L3 so those stats where measure with routing involved.
HTH,
__
Edison.
There is nothing about C3560-8PC, the 8 porter I am looking for.
Joseph W. Doherty
Depending on which specs you examine, you might be able to obtain full wire rate from all ports (for either L2/L3). If true, answer to your question is yes. If not true, very likely switch's L3 performance is (much) more than 100 Mbps.
PS:
Where the specs conflict:
Table 2 in http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps5528/product_data_sheet09186a00801f3d7d.html shows, for performance, 32 Gbps forwarding bandwidth (all 3560s?) and 2.7 Mpps (Cisco Catalyst 3560-8PC), but in Edison's first reference, although the 8 port 3560 isn't listed, other 10/100 3560s are noted with less than 32 Gbps.
The Mpps rating, 2.7 Mpp, is what's needed for wire speed, only whether 3.6 Gbps fabric bandwidth is provided is unclear.
