WS-C3650-24TS and GLC-GE-100FX problem
dmtt
I will try to connect two WS-C3650-24TS switches with GLC-GE-100FX SFP modules. Link is up.
Packet is outcome from one interface, but do not come to another interface. Test with ping. The settings on both switches are the same.
Switch Ports Model              SW Version        SW Image              Mode
*    1 28    WS-C3650-24TS      16.6.2            CAT3K_CAA-UNIVERSALK9 INSTALL
C3650Primary#sh int gigabitEthernet 1/1/1 transceiver
ITU Channel not available (Wavelength not available),
Transceiver is externally calibrated.
If device is externally calibrated, only calibrated values are printed.
++ : high alarm, +  : high warning, -  : low warning, -- : low alarm.
NA or N/A: not applicable, Tx: transmit, Rx: receive.
mA: milliamperes, dBm: decibels (milliwatts).
                                           Optical   Optical
           Temperature  Voltage  Current   Tx Power  Rx Power
Port       (Celsius)    (Volts)  (mA)      (dBm)     (dBm)
Gi1/1/1      37.9       3.26      28.0     -16.7     -16.7
C3650Primary#sh int gigabitEthernet 1/1/1 capa
C3650Primary#sh int gigabitEthernet 1/1/1 capabilities
GigabitEthernet1/1/1
  Model:                 WS-C3650-24TS
  Type:                  100BaseFX SFP
  Speed:                 100
  Duplex:                full,half
  Trunk encap. type:     802.1Q
  Trunk mode:            on,off,desirable,nonegotiate
  Channel:               yes
  Broadcast suppression: percentage(0-100)
  Flowcontrol:           rx-(off,on,desired),tx-(none)
  Fast Start:            yes
  QoS scheduling:        rx-(not configurable on per port basis),
                         tx-(2p6q3t)
  CoS rewrite:           yes
  ToS rewrite:           yes
  UDLD:                  yes
  Inline power:          no
  SPAN:                  source/destination
  PortSecure:            yes
  Dot1x:                 yes
GigabitEthernet1/1/1 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is 7069.5a65.3f99 (bia 7069.5a65.3f99)
  MTU 1500 bytes, BW 10000 Kbit/sec, DLY 1000 usec,
     reliability 253/255, txload 1/255, rxload 1/255
  Keepalive not set
  Full-duplex, 10Mb/s, link type is force-up, media type is 100BaseFX SFP
  input flow-control is off, output flow-control is unsupported
  Last input never, output 00:00:01, output hang never
  Last clearing of "show interface" counters 00:48:46
  Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
     0 packets input, 9664 bytes, 0 no buffer
     Received 0 broadcasts (0 multicasts)
     44 input errors, 44 CRC, 0 frame, 0 overrun, 0 ignored
     0 watchdog, 0 multicast, 0 pause input
     2109 packets output, 154776 bytes, 0 underruns
     0 unknown protocol drops
     0 lost carrier, 0 no carrier, 0 pause output
C3650Primary#sh run int gigabitEthernet 1/1/1
Building configuration...
Current configuration : 104 bytes
interface GigabitEthernet1/1/1
 switchport access vlan 1121
 switchport mode access
 duplex full
end
C3650Secondary#sh int gi1/1/1 transceiver
                                           Optical   Optical
Gi1/1/1      39.6       3.26      32.7     -16.6     -15.7
C3650Secondary#sh int gi1/1/1 capa
C3650Secondary#sh int gi1/1/1 capabilities
  Type:                  100BaseFX SFP
  Speed:                 100
  Duplex:                full,half
  Channel:               yes
  Fast Start:            yes
                         tx-(2p6q3t)
  CoS rewrite:           yes
  ToS rewrite:           yes
  UDLD:                  yes
  Inline power:          no
  PortSecure:            yes
  Dot1x:                 yes
  Hardware is Gigabit Ethernet, address is 7069.5a99.3d19 (bia 7069.5a99.3d19)
  Keepalive not set
  Last clearing of "show interface" counters 00:50:08
     0 packets input, 10143 bytes, 0 no buffer
     45 input errors, 45 CRC, 0 frame, 0 overrun, 0 ignored
     1578 packets output, 121114 bytes, 0 underruns
C3650Secondary#sh run int gi1/1/1
 switchport access vlan 2121
 duplex full
end
dmtt
Downgrade to 03.07.05E (cat3k_caa-universalk9.SPA.03.07.05.E.152-3.E5.bin). Traffic has gone through a 100BaseFx connection. The LED indicator on the port was working correctly. Command 'show interface' show the correct speed of 100Mb/s.
9 Replies 9
Reza Sharifi
Can try removing
duplex full
 from each switch and test again?
I already checked half-duplex, it was by default. Output collision count increased. No input packet.
Upgrade the firmware.
I've seen two bugs with this behaviour.
I will need to trawl through my emails to find the bug IDs.
Which version should I update? 16.6.3 (cat3k_caa-universalk9.16.06.03.SPA.bin)?
Try 16.6.3.
I updated both switches to version 16.6.3 and performed the checks. I did not notice any changes. Problem still exists.
Raise a TAC case.  I believe you're hitting CSCvb69066.
Predrag Jovic
Level 3
Level 3
Which one is correct?
dmtt
