WS-C3750E-48PD etherchannel multi vlan
what am i doing wrong? i can not get the vlans to go over my fiber port channel.
the no commands are what i want, and i have read should work. the rest is current running.
WS-C3750E-48PD, 15.2(4)E10 (UNIVERSALK9)
spanning-tree mode pvst
no spanning-tree vlan 1,101-103,1000
vlan internal allocation policy ascending
vlan dot1q tag native
interface Port-channel1
description LAN trunk 20gb fiber
 switchport mode access
no switchport trunk encapsulation dot1q
no switchport trunk allowed vlan 1-200,1000
no switchport mode trunk
no switchport trunk native vlan 1
interface Port-channel2
description server trunk 2gb cat temp
switchport access vlan 102
no shutdown
interface Port-channel3
description WAN trunk 2gb cat temp
switchport access vlan 1000
no shutdown
interface TenGigabitEthernet1/0/1
description 10g fiber trunk 1 of 2
channel-group 1 mode active
interface TenGigabitEthernet1/0/2
description 10g fiber trunk 2 of 2
interface Vlan1
description LAN
ip address
interface Vlan101
description LAN
ip address
interface Vlan102
description server_link
ip address
interface Vlan103
description cameras
ip address
interface Vlan1000
description WAN
ip address
ip default-gateway .
ip forward-protocol nd
2 Accepted Solutions
balaji.bandi
VIP Community Legend VIP Community Legend
Not sure if i understand your question correctly here.
If you looking your VLAN to go across Port-channel you should allow them to span over.
as per your config, it is mode set to access, this act as access port.
change to below to work, make sure you shut the port-channel make the changes and enable back.
no switchport mode access
if this not what you looking explain more.
BB
so i need to "shut the port-channel make the changes and enable back".
oh. i did not do that. i left the channel live the whole time. did not think i had to bounce it. i will try that.
what you see is two configs in one. i am "working" in the mode access right now.
the "no" commands are what i feel are the proper trunking set up, but dropped my vlans when i did them, but like i said... i did not bounce the channel.
6 Replies 6
balaji.bandi
BB
make changes effective on best way do it always shutdown mode.
so follow below steps to make effective. (make sure you do it console, if your are not doing this config from management interface) - if not you loose connectivityt to switch.
config t
shutdown
no shut
it should work as expected.
let us know the inputs.
BB
Leo Laohoo
Hall of Fame Community Legend Hall of Fame Community Legend
Uhhhh ... whut?
Deepak Kumar
Advocate
Advocate
It seems that your port-channel configuration is not correct:
try as:
config t
default interface TenGigabitEthernet1/0/2
default interface TenGigabitEthernet1/0/1
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
when i shut the channels and then did the changes, and then no shut, it all worked. so use to just making live changes and did not think of the need to re provision the interface on the level 2. if was level 3 (ip address, route, gateway...) would not have been an issue.
thnks!
Recognize Your Peers
