WS-C3850-24P GUI
We have WS-C3850-24P switch we try to open switch on gui based but we getting only startup config on GUI ,we need full GUI Access on switch.
paolo bevilacqua
Wrong forum, post in "LAn and switching". You can move your posting using the Actions panel on the right.
Richard Burts
If you would post the configuration from the switch we might be able to find what is the issue.
Rick
Rick
Mr.Rick
PlZ find the below config
aaa session-id common
clock timezone UTC 5 30
switch 1 provision ws-c3850-24p
ip device tracking
qos wireless-default-untrust
crypto pki trustpoint TP-self-signed-2699291282
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-2699291282
revocation-check none
rsakeypair TP-self-signed-2699291282
crypto pki certificate chain TP-self-signed-2699291282
certificate self-signed 01
  30820242 308201AB A0030201 02020101 300D0609 2A864886 F70D0101 04050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 32363939 32393132 3832301E 170D3133 31303032 30383331
  35385A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D32 36393932
  39313238 3230819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  81009C6B 2FB419B5 9463396C 2B595C12 96A6A187 CE86D211 67F5059F FF43E1E4
  C84CF5BB 0D605FB1 3830C17B F41B737E C9C107BF 5E559070 4CC02B94 E1CDB0F0
  CBF4E57B 7418C510 925F7866 6163B88E CEF37776 F2F4A340 46DAA6D9 E82D8ECF
  734A1B9A C2015C2F C5D40381 24ADDD98 2E059A80 ED1F1D98 0C219B31 E5AA3258
  F56D0203 010001A3 6A306830 0F060355 1D130101 FF040530 030101FF 30150603
  551D1104 0E300C82 0A436F6E 74726F6C 6C657230 1F060355 1D230418 30168014
  4D1A83B3 6C1FC76E 5FFA1622 4C2A9F00 EE992433 301D0603 551D0E04 1604144D
  1A83B36C 1FC76E5F FA16224C 2A9F00EE 99243330 0D06092A 864886F7 0D010104
  05000381 81003502 75431A15 DFFBD974 33ED15A3 301BCAFF 4DCEFF9F EB1DC80B
  2398DAE0 A56240AF 34750C4E 212B95CB 37DA445B 58661F9F 945B5FE8 034BDC63
  4E1EDD40 6FD6DC23 078C17A2 53CE2389 D484F7FF 425AD3DB 1F162E5E AD7BC219
  A95D1E19 EA994482 88B0278E 4B7ADE54 CB822655 DF05A625 473B9733 E2FB03BF
  116F038A 311E
        quit
diagnostic bootup level minimal
identity policy webauth-global-inactive
inactivity-timer 3600
spanning-tree mode rapid-pvst
redundancy
mode sso
class-map match-any non-client-nrt-class
  match non-client-nrt
policy-map port_child_policy
class non-client-nrt-class
    bandwidth remaining ratio 10
interface GigabitEthernet0/0
vrf forwarding Mgmt-vrf
ip address 172.16.10.20 255.255.255.192
negotiation auto
interface GigabitEthernet1/0/1
switchport mode access
shutdown
interface GigabitEthernet1/0/2
switchport access vlan 14
interface GigabitEthernet1/0/3
shutdown
interface GigabitEthernet1/0/4
shutdown
interface GigabitEthernet1/0/5
interface GigabitEthernet1/0/6
shutdown
interface GigabitEthernet1/0/7
shutdown
interface GigabitEthernet1/0/8
shutdown
interface GigabitEthernet1/0/9
shutdown
interface GigabitEthernet1/0/10
shutdown
interface GigabitEthernet1/0/11
shutdown
interface GigabitEthernet1/0/12
interface GigabitEthernet1/0/13
shutdown
interface GigabitEthernet1/0/14
interface GigabitEthernet1/0/15
interface GigabitEthernet1/0/16
interface GigabitEthernet1/0/17
interface GigabitEthernet1/0/18
interface GigabitEthernet1/0/19
interface GigabitEthernet1/0/20
interface GigabitEthernet1/0/21
interface GigabitEthernet1/0/22
switchport access vlan 4
interface GigabitEthernet1/0/23
interface GigabitEthernet1/0/24
switchport mode trunk
interface GigabitEthernet1/1/1
interface GigabitEthernet1/1/2
interface GigabitEthernet1/1/3
interface GigabitEthernet1/1/4
interface TenGigabitEthernet1/1/1
interface TenGigabitEthernet1/1/2
interface TenGigabitEthernet1/1/3
interface TenGigabitEthernet1/1/4
interface Vlan1
ip address 172.16.10.3 255.255.255.192
interface Vlan3
no ip address
interface Vlan4
no ip address
interface Vlan5
no ip address
interface Vlan6
no ip address
interface Vlan14
ip address 172.16.140.2 255.255.255.224
ip helper-address 172.16.140.1
ip http server
ip http secure-server
ip route 0.0.0.0 0.0.0.0 172.16.10.1
radius-server host 10.10.9.40
radius-server host 10.10.9.40 auth-port 1612 key 1234567
ldap server Maxissoftware.com
ipv4 10.10.9.1
base-dn CN=Cacti,OU=MaxisGroup,DC=maxissoftware,DC=com
search-filter user-object-type CN=Cacti,OU=MaxisGroup,DC=maxissoftware,DC=com
ldap server ldap-server
ipv4 10.10.9.1
base-dn OU=Infra,OU=MST,OU=SrManagement,OU=MaxisGroup,DC=maxissoftware,DC=com
search-filter user-object-type objectclass=user)(objectcategory=user)(userPrinc
ipalName=*))
mode secure
authentication bind-first
line con 0
stopbits 1
line aux 0
stopbits 1
line vty 0 4
password cisco
line vty 5 15
wsma agent exec
profile httplistener
profile httpslistener
wsma agent config
wsma agent filesys
wsma agent notify
wsma profile listener httplistener
transport http
wsma profile listener httpslistener
transport https
wsma profile initiator wifi
encap soap12
wireless mobility controller
wireless management interface Vlan14
no wireless broadcast vlan 14
wireless mgmt-via-wireless
wlan guest 2 Guest
no security wpa akm dot1x
shutdown
wlan ldap-test 10 ldap-test
security web-auth authentication-list useldap
shutdown
wlan CA 1 cacorp
aaa-override
no broadcast-ssid
client vlan 14
ip dhcp server 172.16.140.1
ip multicast vlan wifi
media-stream multicast-direct
security wpa akm psk set-key ascii 0 M/-\X15Gr0Up@5EZ2013
no shutdown
wlan MAC-WLAN 12 MAC-WLAN
shutdown
ap dot11 24ghz rrm channel dca 1
ap dot11 24ghz rrm channel dca 6
ap dot11 24ghz rrm channel dca 11
ap dot11 24ghz cleanair
ap dot11 5ghz rrm channel dca 36
ap dot11 5ghz rrm channel dca 40
ap dot11 5ghz rrm channel dca 44
ap dot11 5ghz rrm channel dca 48
ap dot11 5ghz rrm channel dca 52
ap dot11 5ghz rrm channel dca 56
ap dot11 5ghz rrm channel dca 60
ap dot11 5ghz rrm channel dca 64
ap dot11 5ghz rrm channel dca 149
ap dot11 5ghz rrm channel dca 153
ap dot11 5ghz rrm channel dca 157
ap dot11 5ghz rrm channel dca 161
ap dot11 5ghz cleanair
ap group default-group
ap group my-ap-group
wlan wal-test1234
wlan wa1-cacorp
ap group CA
wlan cacorp
end
Controller#
And we getting error WSMA not configured.
