WS-C3850-24U-L does not boot
schizoidman8
Hi, I have this switch 3850 that does not boot, I tried to boot from usb and initialize with the same error. Also the flash is not recognized. Do you have aniy idea to recover this switch form boot process?
6 Replies 6
David Nolasco
In rommon try to initialize the flash using "flash_init" command, if this does not help I would suggest to try the Emergency Recovery Procedure
If still the device is unable to boot, most likely need to be replaced.
David N.
Leo Laohoo
Post the complete output to the following ROMMON commands:
  1. dir flash:
  2. set
RMA the switch.
Already suggested for RMA
Jitendra
Jitendra Kumar
