Bookmark
Subscribe
4640
In cisco ie2000 i had Deleted all file from flesh: please help me
mkumawat1307
I have cisco ie2000 16ptc-g-e and i delete all files from flash: please help me what to do now
21 Replies 21
balaji.bandi
Switch going in boot loader mode only
I already use this methods (Switch: copy xmodem: flash:image_filename.bin) but after copy this bin file when i boot this bin file then switch goes in loop. Now what to do
make sure that the image file is visible in the directory you copied it to using xmodem, then attempt to boot from it, copy the console log showing all the output from this plus the "loop" events here.
next step is do the same steps, this time capture all the console logs and attached here to look what went to wrong ?
if this is emergency you can open a TAC case if you have support.
BB
Console into the switch and reboot.  Post the entire boot-up process.  We want to see the switch when it goes into the boot loop state.
Also, what is the exact model number of the switch?
mkumawat1307
im uploading bin file in switch again but it take 8 to 9 hours because i cant set BAUD rate to 115200.
switch: set BAUD 115200
Can't set BAUD for SD env, please use <set -p>
Switch model; IE-2000-16PTC-G-E
Look at the IE2000.  Does it have an SD card?
no sd card in switch
Console into the switch and boot it.  Post the entire boot-up process.
At the end of the boot-up to ROMMON, post the complete output to the following commands:
  • dir flash:
  • set
switch:
switch:
switch: dir flash:
Directory of flash:/
2 -rwx 27244928 <date> ie2000-universalk9-mz.152-7.E2.bin
29751K bytes available (26822K bytes used)
switch:
switch: set
Env Vars for Primary Flash:
SKIP_MEMTEST=1
115200=
BOARD_CONFIG_REV=0
BOOT=flash:ie2000-universalk9-mz.152-4.EA5/ie2000-universalk9-mz.152-4.EA5.bin
CIP_SERIAL_NUM=51230900
DAUGHTERBOARD_ASSEMBLY_NUM10=73-13836-01
DAUGHTERBOARD_ASSEMBLY_NUM11=73-13684-02
DAUGHTERBOARD_ASSEMBLY_NUM6=73-13682-02
DAUGHTERBOARD_ASSEMBLY_NUM7=73-15118-02
DAUGHTERBOARD_ASSEMBLY_NUM8=73-13679-02
DAUGHTERBOARD_ASSEMBLY_NUM9=73-13724-02
FAST_BOOT_ENABLED=yes
MAC_ADDR=F8:B7:E2:23:09:00
MODEL_NUM=IE-2000-16PTC-G-E
MODEL_REVISION_NUM=P0
MOTHERBOARD_ASSEMBLY_NUM=73-15729-01
MOTHERBOARD_REVISION_NUM=H0
MOTHERBOARD_SERIAL_NUM=FDO21351V33
-- MORE --
PN_SET=no
RESET_REASON=Reload command
SDM_TEMPLATE_ID=5
SKIP_FSCK=yes
SKIP_POST=yes
SWITCH_PRIORITY=1
SYSTEM_DOWNSHIFT_CFG=1
SYSTEM_DOWNSHIFT_COUNTER_CFG=3
SYSTEM_SERIAL_NUM=FDO2136T00J
TAN_NUM=800-40005-01
TAN_REVISION_NUMBER=P0
VERSION_ID=V01
Env Vars for Secondary Flash:
switch:
switch:
switch: boot flash:ie2000-universalk9-mz.152-7.E2.bin
Loading "flash:ie2000-universalk9-mz.152-7.E2.bin"...#################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################
File "flash:ie2000-universalk9-mz.152-7.E2.bin" uncompressed and installed, entry point: 0x3000
executing...
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
Cisco IOS Software, IE2000 Software (IE2000-UNIVERSALK9-M), Version 15.2(7)E2, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2020 by Cisco Systems, Inc.
Compiled Sun 15-Mar-20 06:34 by prod_rel_team
Initializing flashfs...
Using driver version 4 for media type 1
mifs[4]: 11 files, 1 directories
mifs[4]: Total bytes : 1806336
mifs[4]: Bytes used : 741376
mifs[4]: Bytes available : 1064960
mifs[4]: mifs fsck took 0 seconds.
mifs[4]: Initialization complete.
mifs[5]: 1 files, 1 directories
mifs[5]: Total bytes : 3870720
mifs[5]: Bytes used : 133632
mifs[5]: Bytes available : 3737088
mifs[5]: mifs fsck took 0 seconds.
mifs[5]: Initialization complete.
mifs[6]: 5 files, 1 directories
mifs[6]: Total bytes : 258048
mifs[6]: Bytes used : 9216
mifs[6]: Bytes available : 248832
mifs[6]: mifs fsck took 0 seconds.
mifs[6]: Initialization complete.
mifs[7]: 5 files, 1 directories
mifs[7]: Total bytes : 258048
mifs[7]: Bytes used : 9216
mifs[7]: Bytes available : 248832
mifs[7]: mifs fsck took 0 seconds.
mifs[7]: Initialization complete.
mifs[8]: 1 files, 1 directories
mifs[8]: Total bytes : 57931776
mifs[8]: Bytes used : 27466240
mifs[8]: Bytes available : 30465536
mifs[8]: mifs fsck took 0 seconds.
mifs[8]: Initialization complete.
...done Initializing flashfs.
Checking for Bootloader upgrade..
Boot Loader upgrade not needed(v)
POST: CPU MIC register Tests : Begin
POST: CPU MIC register Tests : End, Status Skipped
POST: PortASIC Memory Tests : Begin
POST: PortASIC Memory Tests : End, Status Skipped
POST: CPU MIC interface Loopback Tests : Begin
POST: CPU MIC interface Loopback Tests : End, Status Skipped
POST: PortASIC RingLoopback Tests : Begin
POST: PortASIC RingLoopback Tests : End, Status Skipped
Upgrading Jeeves FPGA firmware...
%Error stat'ing ucode0:jeevesfpga.rbf (No such file or directory)
Jeeves FPGA Upgrade failed...
Loading Jeeves FPGA Golden Image...
FPGA version 0.14 downloaded successfully
Base ethernet MAC Address: f8:b7:e2:23:09:00
Xmodem file system is available.
The password-recovery mechanism is enabled.
Initializing Flash...
mifs[2]: 11 files, 1 directories
mifs[2]: Total bytes : 1806336
mifs[2]: Bytes used : 741376
mifs[2]: Bytes available : 1064960
mifs[2]: mifs fsck took 0 seconds.
mifs[3]: 1 files, 1 directories
mifs[3]: Total bytes : 3870720
mifs[3]: Bytes used : 133632
mifs[3]: Bytes available : 3737088
mifs[3]: mifs fsck took 0 seconds.
mifs[4]: 5 files, 1 directories
mifs[4]: Total bytes : 258048
mifs[4]: Bytes used : 9216
mifs[4]: Bytes available : 248832
mifs[5]: 5 files, 1 directories
mifs[5]: Total bytes : 258048
mifs[5]: Bytes used : 9216
mifs[5]: Bytes available : 248832
mifs[6]: 1 files, 1 directories
mifs[6]: Total bytes : 57931776
mifs[6]: Bytes used : 27466240
mifs[6]: Bytes available : 30465536
...done Initializing Flash.
done.
SD card is not present.
Loading "flash:/ie2000-universalk9-mz.152-7.E2.bin"...#################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################
File "flash:/ie2000-universalk9-mz.152-7.E2.bin" uncompressed and installed, entry point: 0x3000
executing...
cisco Systems, Inc.
done.
executing...
cisco Systems, Inc.
Right, I know what is going on.
A lot of people like to "upgrade" a switch firmware by copying the BIN file.  Well, for the IE2k, that is not going to work.
Why?  Because the TAR file contains a specific microcode/FPGA file and this file is totally separate to the BIN file.
See this?  This is why I need to see the output to the "set" command.
I want to see what was the original firmware of the switch.  Find this file, the BIN file this time, and upload it to the switch via XModem or SD Flash.
Only then can the switch be upgraded using the TAR file using the following, well-known and recommended procedure:
archive download-sw tftp://<TFTP_IP_ADDRESS>/TAR_FILENAME.TAR
How to upload a tar file in switch in rommon mode can u tell me whole procedure
are u saying i upload only ie2000-universalk9-mz.152-4.EA5.bin file in switch after that boot this file
