WS-C4506E Sup 6E - Avaya VoIP Configuration Settings
NC16390371
I am trying to get a second set of eyes with folks that have experience configuring WS-C4506E's to support Avaya VoIP PoE phones.  The following is the configuration that has been applied.  I would like to see if their are any improvements that I can make to provide the best configuration.  Please note I have limited exposure and experience with applying QoS settings to LAN Switches.  If there other questions or it makes sense to post a particular output please do not hesitate to let me know.  Thanks
! Global QoS Commands
qos dbl
qos map dscp 24 25 26 27 28 29 30 32 to tx-queue 4
qos map dscp 32 33 34 35 36 37 38 39 to tx-queue 4
qos map dscp 40 41 42 43 44 45 47 to tx-queue 4
qos map cos 3 to dscp 26
qos map cos 5 to dscp 46
class-map match-all AutoQos-VoIP-Cos-1
  match cos  1
class-map match-all AutoQos-VoIP-Cos-2
  match cos  2
class-map match-all AutoQos-VoIP-Cos-4
  match cos  4
class-map match-all AutoQos-VoIP-Cos-6
  match cos  6
class-map match-all AutoQos-VoIP-Cos-7
  match cos  7
class-map match-all AutoQos-VoIP-Bearer-Cos
  match cos  5
class-map match-all AutoQos-VoIP-Control-QosGroup24
  match  dscp cs3
class-map match-all AutoQos-VoIP-Control-QosGroup26
  match  dscp af31
class-map match-all AutoQos-VoIP-Bearer-QosGroup
  match  dscp ef
class-map match-all AutoQos-VoIP-Control-Cos
  match cos  3
policy-map AutoQos-VoIP-Input-Cos-Policy
class AutoQos-VoIP-Bearer-Cos
   set dscp ef
class AutoQos-VoIP-Control-Cos
   set dscp af31
class AutoQos-VoIP-Cos-2
   set dscp cs2
class AutoQos-VoIP-Cos-1
   set dscp cs1
class AutoQos-VoIP-Cos-4
   set dscp af41
class AutoQos-VoIP-Cos-6
   set dscp cs6
class AutoQos-VoIP-Cos-7
   set dscp cs7
policy-map AutoQos-VoIP-Output-Policy-Trunk
class AutoQos-VoIP-Bearer-QosGroup
   set dscp ef
   set cos 5
    priority
    police cir percent 60
class AutoQos-VoIP-Control-QosGroup26
   set dscp af31
   set cos 3
    bandwidth remaining percent 5
class AutoQos-VoIP-Control-QosGroup24
   set dscp cs3
   set cos 3
class class-default
    dbl
   set dscp ef
   set cos 5
    priority
    police cir percent 33
   set dscp af31
   set cos 3
   set dscp cs3
   set cos 3
class class-default
    dbl
! Sample - Core/Distribution Layer Uplink Port
interface range gi1/3
switchport trunk encap dot1q
switchport mode trunk
qos trust dscp
auto qos voip trust
service-policy input AutoQos-VoIP-Input-Cos-Policy
service-policy output AutoQos-VoIP-Output-Policy-Trunk1
! Sample - Access Layer Port
interface fa2/1
switchport access vlan 100
switchport voice vlan 200
switchport mode acces
qos trust dscp
auto qos voip trust
tx-queue 3
priority high
spanning-tree portfast
exit
Dennis Mink
This is pretty much a stock standard AutoQos configuration
ONe thing you have to make sure is the values in the following groups:
   set dscp af31
   set cos 3
   set dscp cs3
   set cos 3
because you have your access port set to trust any incoming dscp value, you must make sure that your phones are set to send the right DSCP value.
I am not sure where you set that in Avaya, but make sure you double check.
Please remember to rate useful posts, by clicking on the stars below.
   set dscp af31
   set cos 3
   set dscp cs3
   set cos 3
I too am deploying a 4510E with a sup7E in our environment. This is a new sup module that we don't have as part of our WAN enterprise till now.
I was looking for the same answers regarding AVAYA 4620 model phones.
If possible can we have a bullet proof configuration for QoS for these switches? The phones use DSCP. I'm not sure that auto qos voip trust would be the right parameter to put in under the interface configuraitons. The policy map generated may include unwanted parameters. Does anyone else have this phone and switch setup that I can use for our new deployment that is tested and proven?
