12-05-2013 01:22 AM - edited 03-07-2019 04:56 PM
hi All,
i have a question regarding 4500
i already have a Cisco WS-C4507R chassis with Supervisor II+ and i need to add another core switch WS-C4507R+E with Supervisor 7-LE to work in active active mode as VSS through the 2G uplinks on the both supervisor
is this applicable to be done
and if yes , is there any limitation or prerequisites to make this work
Solved! Go to Solution.
12-05-2013 04:42 AM
Mahmoud
Do you mean run VSS between your 4507R and the new 4507R+E ? If so then no you can't do this as the orginal chassis plus the supervisor II+ does not support VSS. See this link for hardware requirements needed for VSS -
Jon
12-05-2013 04:42 AM
Mahmoud
Jon
12-05-2013 05:19 AM
If you need to run VSS then you would have to replace the original 4507R with the newer version.
12-05-2013 05:28 AM
Thanks Jon and glen for ur add
i found that VSS is available on Supervisor Engine 7-E, Supervisor Engine 7L-E
and the classic 4507R only support Supervisor Engine 6-E, 6L-E, V-10GE, V, IV, II-Plus-10GE, II-Plus
so the only way is to replace the 4570R with the newer E-series one as glen said
