WS-C4507R+E+IP PIM SM DM mode configuratin problem
sheraz butt
Hi All,
 I trying to configure ip pim sm or ip pim dm in core swith for iptv but its not taking the commands ip multicast-routing is enabled.
Vlan 30:
IGMP snooping                       : Enabled
CAPWAP enabled                      : Disabled
IGMPv2 immediate leave              : Enabled
Explicit host tracking              : Enabled
Multicast router learning mode      : pim-dvmrp
CGMP interoperability mode          : IGMP_ONLY
Last member query interval          : 1000
CORE1(config)#inter vlan 30
CORE1(config-if)#ip pim
CORE1(config-if)#ip pim ?
% Unrecognized command
CORE1(config)#interface gigabitEthernet 2/2
any help
regards
2 Accepted Solutions
ranraju
Hi Sheraz,
Can you post "show version" and "show module" output of the concerned switch here?
Ranganath
Hi ,
Thank you for those outputs.
If you notice in show version, you are using lanbase license...
License Information for 'WS-X45-SUP7-E'
    License Level: lanbase   Type: Default. No valid license found.
    Next reboot license Level: lanbase
So, you surely wont be able to run pim on the switch with just lanbase license, as it will have limited features in lanbase. Try to use entservices, you should be able to enable pim after that.
Ranganath
5 Replies 5
ranraju
Hi Sheraz,
Ranganath
CORE1#show version
Cisco IOS Software, IOS-XE Software, Catalyst 4500 L3 Switch Software (cat4500e-UNIVERSAL-M), Version 03.04.02.SG RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Thu 05-Sep-13 20:34 by prod_rel_team
Cisco IOS-XE software, Copyright (c) 2005-2010, 2012 by cisco Systems, Inc.
All rights reserved.  Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0.  The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY.  You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0.  For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: 15.0(1r)SG5
CORE1 uptime is 3 days, 5 hours, 7 minutes
Uptime for this control processor is 3 days, 5 hours, 9 minutes
Running default software
Jawa Revision 7, Snowtrooper Revision 0x0.0x1C
Last reload reason: power-on
cisco WS-C4507R+E (MPC8572) processor (revision 10) with 2097152K/20480K bytes of memory.
Processor board ID FXS1650Q0US
MPC8572 CPU at 1.5GHz, Supervisor 7
Last reset from PowerUp
7 Virtual Ethernet interfaces
96 Gigabit Ethernet interfaces
4 Ten Gigabit Ethernet interfaces
511K bytes of non-volatile configuration memory.
Configuration register is 0x2101
CORE1#
CORE1#show module
Chassis Type : WS-C4507R+E
Power consumed by backplane : 40 Watts
Mod Ports Card Type                              Model              Serial No.
 1    48  1000BaseX SFP                          WS-X4448-GB-SFP    JAE170901WY
 2    48  1000BaseX SFP                          WS-X4448-GB-SFP    JAE171001XR
 3     4  Sup 7-E 10GE (SFP+), 1000BaseX (SFP)   WS-X45-SUP7-E      CAT1702L3T2
 M MAC addresses                    Hw  Fw           Sw               Status
 1 2894.0f5f.3e50 to 2894.0f5f.3e7f 1.3                               Ok
 2 0026.0b40.0e00 to 0026.0b40.0e2f 1.3                               Ok
 3 7cad.748a.0e00 to 7cad.748a.0e03 2.1 15.0(1r)SG5  03.04.02.SG      Ok
Mod  Redundancy role     Operating mode      Redundancy status
 3   Active Supervisor   RPR                 Active
CORE1#
Hi ,
Ranganath
HI Ranganath,
for  entservices we need to purchase .lic ?.
and Thanks for reply
hi ,
Yes you will have to, you can still enable license on the switch for trial, but will get truned off after 80 days or so.
You can use show license all command to check if you can enable it temporarily.
Ranganath
