WS-C4507R+E Replacement Product
QUARK TARO
I need to replace the following product as-is due to obsolescence. Please suggest the replacement product and model
WS-C4507R+E (Chassis)
WS-X45-SUP6L-E (Supervisor Engine)
WS-X4648-RJ45-E (Line card for 48x 10/100/1000(RJ45))
WS-X4624-SFP-E (Line card for 24x GE(SFP))
@taro75
First it is not the same OS: Nexus 7000: NX-OS - C9407R:IOS-XE
Also, in terms of raw capacity and performance, the Nexus 7000 series is generally designed for larger-scale data center deployments with higher performance requirements compared to the C9400 Series.
The choice between the Nexus 7000 and C9400 would depend on the specific requirements of your network. If you are designing for a large-scale data center environment with high-density and performance needs, the Nexus 7000 might be more suitable. For enterprise campus networks, the Catalyst 9400 is a versatile and scalable option.
Best regards
5 Replies 5
M02@rt37
Hello @QUARK TARO
Replacement for WS-C4507R+E chassis is Cisco Catalyst 9400 Series 7 slot chassis.
Product number : C9407R(=) /Datasheet
Refer here:https://www.cisco.com/c/en/us/products/collateral/switches/catalyst-4500-series-switches/eos-eol-notice-c51-743088.html
Best regards
What is the difference between Nexus 7000 & C9407R model? Is 7000 capacity is higher than C9407R?
@taro75
Best regards
Thank You, on cisco site 9000 is listed under "Access" category. Does access category includes routing functions?
@taro75
For entry level with full routing and switching, you'll nee Network Advantage license.
License about C9400 series:
https://www.cisco.com/c/en/us/products/collateral/switches/catalyst-9400-series-switches/nb-06-cat9400-swit-ser-cte-en.html#SmartAccountandSmartLicenseavailability
Best regards
