ws-c4948 10G I could use some help please.
So I'm brand new to Cisco awesome equipment though. I bought a switch and when I first booted it up it was stuck in a boot-loop. So I researched and read and through trial and error I got it unstuck and the correct image in place. So I am configuring the switch have not done a tftp server yet and follow a wrong procedure and assign the wrong ip address to the switch I was supposed to be doing a loop-back. So I figured I would just start over good practice right. I'm trying to self teach myself Cisco here that should tell you I'm not the brightest crayon in the box. So I  do a clear config all and it works great so great that even though I had supposedly done a running config save I now have no boot image no slot0 image and no boot system flash bootflash image. I did however make me a tftp server with tftp64 but cant for the life of me get the command right for Rommon to drop me an image. Hell at one point I could see on a reset it said boot  booted from 0x010 cat4500-entservicesk9-mz.150-2.SG10.bin it was right there just not in the right position I have been driving myself crazy here could someone please throw me in the right direction?
Rom Monitor Program Version 12.2(31r)SGA4
Supervisor: WS-C4948 Chassis: WS-C4948
Hardware Revisions - Board: 6.0 CPLD: 4 Dagobah: 225
MAC Address : 00-15-c6-de-ef-ff
IP Address : 192.168.0.69
Netmask : 255.255.255.0
Gateway : 192.168.0.1
TftpServer : 192.168.0.6
Main Memory : 256 MBytes
***** The system will autoboot in 5 seconds *****
Type control-C to prevent autobooting.
Established physical link 100MB Full Duplex
Network layer connectivity may take a few seconds
******** The system will autoboot now ********
config-register = 0x102
Autobooting using BOOT variable specified file.....
Could not find a valid file in BOOT environment variable.
BOOT variable can be set from IOS. To find currently set
Rom Monitor variables, please type 'set' command.
For help on choosing a boot method, type 'confreg' command.
rommon 1 >
32 Replies 32
thats the thing no one was home during the day I got home and it was back to the other image. I put in the 142  to see if it would boot back to the right image it didn't so I did the bootflash cat again and it came back so now I am going to clear the other image hopefully.
Switch#show running-config
Building configuration...
Current configuration : 2227 bytes
version 15.0
no service pad
service compress-config
hostname Switch
boot-start-marker
boot-end-marker
no aaa new-model
ip subnet-zero
ip vrf mgmtVrf
Chassis Type : WS-C4948
Power consumed by backplane : 0 Watts
Mod Ports Card Type Model Serial No.
1 48 1000BaseX (SFP) Supervisor WS-C4948 FOX084307L3
M MAC addresses Hw Fw Sw Status
1 0015.c6de.efc0 to 0015.c6de.efef 1.2 12.2(31r)SGA 15.0(2)SG10 Ok
Switch#
Switch# show module
Post the complete output to the following commands:
1. sh version; and
2. dir
ok I can not for the life of me get that other image to delete
delete /f /r bootflash:at4500-ios-promupgrade-122_31r_SGA4
ickedsswitch>sh version
Cisco IOS Software, Catalyst 4500 L3 Switch Software (cat4500-ENTSERVICESK9-M), Version 15.0(2)SG10, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2015 by Cisco Systems, Inc.
Compiled Tue 07-Apr-15 09:46 by prod_rel_team
Image text-base: 0x10000000, data-base: 0x123AE824
ROM: 12.2(31r)SGA4
Dagobah Revision 225, Swamp Revision 4
wickedsswitch uptime is 51 minutes
System returned to ROM by abort at PC 0x0
System image file is "bootflash:cat4500-entservicesk9-mz.150-2.SG10.bin"
to comply with U.S. and local laws, return this product immediatel
wickedsswitch>ckedsswitch>sh version
% Invalid input detected at '^' marker.
wickedsswitch>$-ENTSERVICESK9-M), Version 15.0(2)SG10, RELEASE SOFTWARE (fc1)
Cisco IOS Software, Catalyst 4500 L3 Switch Software (cat4500-ENTSERVICESK9-M), ^Version 15.0(2)SG10, RELEASE SOFTWARE (fc1)
wickedsswitch>Technical Support: http://www.cisco.com/techsupport
wickedsswitch>Copyright (c) 1986-2015 by Cisco Systems, Inc.
wickedsswitch>Compiled Tue 07-Apr-15 09:46 by prod_rel_team
wickedsswitch>Image text-base: 0x10000000, data-base: 0x123AE824
wickedsswitch>
wickedsswitch>ROM: 12.2(31r)SGA4
wickedsswitch>Dagobah Revision 225, Swamp Revision 4
wickedsswitch>
wickedsswitch>wickedsswitch uptime is 51 minutes
wickedsswitch>System returned to ROM by abort at PC 0x0
wickedsswitch>$e file is "bootflash:cat4500-entservicesk9-mz.150-2.SG10.bin"
wickedsswitch>
wickedsswitch>
wickedsswitch>$t contains cryptographic features and is subject to United
wickedsswitch>$local country laws governing import, export, transfer and
wickedsswitch>use. Delivery of Cisco cryptographic products does not imply
wickedsswitch>$ authority to import, export, distribute or use encryption.
wickedsswitch>$exporters, distributors and users are responsible for
wickedsswitch>$with U.S. and local country laws. By using this product you
wickedsswitch>$mply with applicable laws and regulations. If you are unable
wickedsswitch>$ith U.S. and local laws, return this product immediatel
Look at your cursor: The symbol is ">" instead of "#".
You won't be able to delete anything if you are not in Enable mode.
Directory of bootflash:/
1 -rwx 424748 Nov 19 2014 18:00:29 +00:00 cat4500-ios-promupgrade-122_31r_SGA4
2 -rwx 19476896 Jan 29 2000 11:05:49 +00:00 cat4500-entservicesk9-mz.150-2.SG10.bin
3 -rw- 1202 Jan 1 2000 00:00:04 +00:00 post-2000.01.01.00.00.04-failed.txt
4 -rw- 1202 Jan 1 2000 00:02:38 +00:00 post-2000.01.01.00.02.38-failed.txt
5 -rw- 1202 Jan 1 2000 00:05:12 +00:00 post-2000.01.01.00.05.12-failed.txt
6 -rw- 1202 Jan 1 2000 00:09:16 +00:00 post-2000.01.01.00.09.16-passed.txt
7 -rw- 1202 Jan 1 2000 00:11:50 +00:00 post-2000.01.01.00.11.50-failed.txt
60817408 bytes total (40908848 bytes free)
8 -rw- 1202 Jan 1 2000 14:46:35 +00:00 post-2000.01.01.14.46.35-failed.txt
9 -rw- 1202 Jan 1 2000 15:06:58 +00:00 post-2000.01.01.15.06.58-failed.txt
10 -rw- 1202 Jan 1 2000 15:12:42 +00:00 post-2000.01.01.15.12.42-failed.txt
ok so I finally got rid of the other image and have no first slot but when it starts up what do all the failed posts mean.
In Enable mode, use this command: del /f r flash:post*.txt
That config-register value is wrong.
Plus, delete the ROMMON file "delete /f /r bootflash:cat4500-ios-promupgrade-122_31r_SGA4".
