WS-C6500-E bootup problems
jaattacisco
When i boot up my WS-C6500-E only the supervisor module gets powered up. The other modules are completely dark. I think the supervisor has a problem in the module bringup process. Her is a print of the supervisor diagnostics:
Current bootup diagnostic level: minimal
Module 5 : 9-port 1000BaseX Supervisor, Serial No : SAL1021P5C0
Environmental Status (. = Pass, F = Fail, U = Unknown, N = Not Present)
PS1: F PS2: F PS1 Fan: F PS2 Fan: F
Chassis-Ser-EEPROM: F
Clock(A/B): A Clock A: . Clock B: .
VTT1: . VTT2: . VTT3: .
Network Management Processor (NMP) Status: (. = Pass, F = Fail, U = Untested)
ROM: . Flash-EEPROM: . Ser-EEPROM: . NVRAM: . EOBC Comm: F
Line Card Firmware Status for Module 5 : PASS
Line Card Diag Status for Module 5 (. = Pass, F = Fail, N = N/A, U = Untested)
Port Status :
Ports 1 2 3 4 5 6 7 8 9
SFP Status :
N N N N N N N N N
Module 5:
Overall Diagnostic Result for Module 5 : MAJOR ERROR
Diagnostic level at card bootup: minimal
Test results: (. = Pass, F = Fail, U = Untested)
1 ) FirmwareDiagStatus --------------> .
2 ) TestLoopback:
F F F F F F F F F
3 ) TestActiveToStandbyLoopback:
U U U U U U U U U
4 ) TestTxPathMonitoring ------------> U
5 ) TestInlineRewrite:
U U U U U U U U U
6 ) TestActiveToStandbyInlineRw:
U U U U U U U U U
7 ) TestNewLearn --------------------> F
8 ) TestIndexLearn ------------------> F
9 ) TestDontLearn -------------------> U
10 ) TestDontForward -----------------> U
11 ) TestConditionalLearn ------------> F
12 ) TestBadBpdu ---------------------> U
13 ) TestTrap ------------------------> U
14 ) TestMatch -----------------------> U
15 ) TestSpan ------------------------> U
16 ) TestCapture ---------------------> U
17 ) TestProtocolMatch ---------------> U
18 ) TestChannel ---------------------> U
19 ) TestL3Span ----------------------> F
20 ) TestFibDevices ------------------> F
21 ) TestIPv4FibShortcut -------------> F
22 ) TestL3Capture2 ------------------> F
23 ) TestL3VlanMet -------------------> F
24 ) TestAclPermit -------------------> F
25 ) TestAclDeny ---------------------> F
26 ) TestQoSTcamTest -----------------> F
27 ) TestFibTcamSSRAM ----------------> U
Leo Laohoo
I'm suspecting it's because of your power supply. What is your current power supply and what are your cards?
Im not sure exactly what model the powersupplies are but both the 'input ok' and 'fan ok' LEDs are green on both. I have tried moving the supervisor to different locations but always with the same result. I have 1 module with 48 ethernet ports and 4 modules with 24 MTRJ (fiber) ports each. I tried moving theese around but without results.
Mark Yeates
Level 7
Level 7
I would put in a TAC case on this. Something is not right with the supervisor showing a "MAJOR ERROR". It appears to be a hardware problem with the supervisor in slot five.
HTH,
Mark
