WS-X45-SUP6L-E issue
Muthukumar P
Level 4
Level 4
I have installed the Cisco 4506E with WS-X45-SUP6L-E and WS-X4648-RJ45V+E module.
the IOS is (default) cat4500e-ipbase-mz.122-52.XO.bin now the status LED is in orange (as if some boot process is going or some tests are going),In fact the recommanded minimun IOS is cat4500e-ipbasek9-mz.122-53.SG1.bin,I have tried with many higer IOS versions.Still the status LED is in Orange only,I am not able to link thw other access switches to this ......
Then I tried with the following config-reg values like 0x2101 an d0x2102.
When I change to 0x2102 after the reload command it goes to ROMMON mode.If I change to 0x2101 then after reload command it boots normally but in either case the STATUS LED of teh SUP module is in Orange only not turning to Green.The LED status of the other module is in Green.
Many time I have resetted teh switch by switching OFF the switch and also through the RESET button.I have removed teh module and re-installed also.
Can any one help me to resolve this issue.?
Steve
vaib7av.shirkul
Level 3
Level 3
Can you send below output,
show inventory
show module
sh interfaces status err-disabled
sh hw-module module port-group
sh interfaces  transceiver module 1
Vaibhav
5 Replies 5
vaib7av.shirkul
Level 3
Level 3
show inventory
show module
Vaibhav
Hi Mr.Vaibah,
Thanks for your response.
The following details what you asked.
CORESW#sh inventory
NAME: "Switch System", DESCR: "Cisco Systems, Inc. WS-C4506-E 6 slot switch "
PID: WS-C4506-E , VID: V02 , SN: FOX1433G67K
NAME: "Linecard(slot 1)", DESCR: "Supervisor 6L-E 10GE (X2), 1000BaseX (SFP)with 2 10GE X2 ports"
PID: WS-X45-SUP6L-E , VID: V03 , SN: JAE14270GYC
NAME: "Linecard(slot 2)", DESCR: "1000BaseX (SFP) with 48 SFP ports"
PID: WS-X4448-GB-SFP , VID: V05 , SN: JAE14150A4M
NAME: "GigabitEthernet2/1", DESCR: "1000BaseSX"
PID: Unspecified , VID: , SN: FNS12100PSM
NAME: "GigabitEthernet2/2", DESCR: "1000BaseSX"
PID: Unspecified , VID: , SN: FNS12100F0Y
NAME: "GigabitEthernet2/3", DESCR: "1000BaseSX"
PID: Unspecified , VID: , SN: FNS14280530
NAME: "GigabitEthernet2/4", DESCR: "1000BaseSX"
PID: Unspecified , VID: , SN: AGM1419125Z
NAME: "GigabitEthernet2/15", DESCR: "1000BaseSX"
PID: Unspecified , VID: , SN: AGM141910D8
NAME: "GigabitEthernet2/16", DESCR: "1000BaseSX"
PID: Unspecified , VID: , SN: AGM141819H5
NAME: "GigabitEthernet2/17", DESCR: "1000BaseSX"
PID: Unspecified , VID: , SN: FNS1428168B
NAME: "GigabitEthernet2/18", DESCR: "1000BaseSX"
PID: Unspecified , VID: , SN: FNS142815N8
NAME: "Linecard(slot 3)", DESCR: "10/100/1000BaseT (RJ45)+V E Series with 48 10/100/1000 baseT Premium PoE ports (Cisco/IEE"
PID: WS-X4648-RJ45V+E , VID: V05 , SN: JAE14420GV5
NAME: "Fan", DESCR: "FanTray"
PID: WS-X4596-E , VID: V03 , SN: FOX1432GG0R
NAME: "Power Supply 1", DESCR: "Power Supply ( AC 2800W )"
PID: PWR-C45-2800ACV , VID: V05 , SN: SNI1417A3K8
NAME: "Power Supply 2", DESCR: "Power Supply ( AC 2800W )"
PID: PWR-C45-2800ACV , VID: V05 , SN: SNI1417A3RM
CORESW#sh inventory                               mod
Chassis Type : WS-C4506-E
Power consumed by backplane : 0 Watts
Mod Ports Card Type Model Serial No.
1 6 Sup 6L-E 10GE (X2), 1000BaseX (SFP) WS-X45-SUP6L-E JAE14270GYC
2 48 1000BaseX SFP WS-X4448-GB-SFP JAE14150A4M
3 48 10/100/1000BaseT Premium POE E Series WS-X4648-RJ45V+E JAE14420GV5
M MAC addresses Hw Fw Sw Status
1 f866.f2b0.74c0 to f866.f2b0.74c5 1.3 12.2(44r)SG5 12.2(52)XO Ok
2 68ef.bda9.ab50 to 68ef.bda9.ab7f 1.3 Ok
3 588d.09e1.3200 to 588d.09e1.322f 2.0 Ok
System Failures:
Power Supply: bad/off (see 'show power')
CORESW#sh inter
CORESW#sh interfaces status err-disabled
CORESW#sh hw-mo
CORESW#sh hw-module mo
CORESW#sh hw-module module po
CORESW#sh hw-module module port-group ?
<0-0> port-group number
| Output modifiers
Module Port-group Active Inactive
1 1 Te1/1 Gi1/3-4
1 2 Te1/2 Gi1/5-6
2 COMMAND NOT SUPPORTED
3 COMMAND NOT SUPPORTED
4 COMMAND NOT SUPPORTED
5 COMMAND NOT SUPPORTED
6 COMMAND NOT SUPPORTED
CORESW#sh inte
CORESW#sh interfaces tra
CORESW#sh interfaces transceiver mod
CORESW#sh interfaces transceiver module q   1
CORESW#
Steve
Try below commands to check the errors in chassis,
I tried the below commands on chassis, I got following output,
Hope you will get same,
SW#sh diagnostic result module all detail
Current bootup diagnostic level: minimal
module 1:   SerialNo : JAE15340f3E
  Overall Diagnostic Result for module 1 : PASS
  Diagnostic level at card bootup: minimal
  Test results: (. = Pass, F = Fail, U = Untested)
  ___________________________________________________________________________
    1) supervisor-bootup ---------------> .
          Error code ------------------> 0 (DIAG_SUCCESS)
          Total run count -------------> 1
          Last test testing type ------> n/a
          Last test execution time ----> Jan 03 2012 05:22:43
          First test failure time -----> n/a
          Last test failure time ------> n/a
          Last test pass time ---------> Jan 03 2012 05:22:43
          Total failure count ---------> 0
          Consecutive failure count ---> 0
Power-On-Self-Test Results for ACTIVE Supervisor
prod: WS-X45-SUP6L-E part: 73-13067-03 serial: JAE15340f3E
Power-on-self-test for Module 1: WS-X45-SUP6L-E
CPU Subsystem Tests ...
seeprom: Pass
Traffic: L3 Looopback ...
Test Results: Pass
Traffic: L2 Loopback ...
Test Results: Pass
Switching Subsystem Memory ...
Packet Memory Test Results: Pass
Module 1 Passed
    2) linecard-online-diag ------------> .
Slot Ports Card Type                              Diag Status      Diag Details
1     6   Sup 6L-E 10GE (X2), 1000BaseX (SFP)    Skipped          Packet memory
Detailed Status
. = Pass              U = Unknown
L = Loopback failure  S = Stub failure
P = Port failure
E = SEEPROM failure   G = GBIC integrity check failure
Ports 1   2   3   4   5   6
module 2:   SerialNo : JAE1348P8R2
  Overall Diagnostic Result for module 2 : PASS
    1) linecard-online-diag ------------> .
2    18   10GE (X2), 1000BaseX (SFP)             Passed           None
Detailed Status
P = Port failure
Ports 1   2   3   4   5   6   7   8   9   10  11  12  13  14  15  16
Ports 17  18
module 3:   SerialNo : JAE153134EB
  Overall Diagnostic Result for module 3 : PASS
3    18   10GE (X2), 1000BaseX (SFP)             Passed           None
Detailed Status
P = Port failure
Ports 17  18
SW#sh diagnostic events module all
Diagnostic events (storage for 500 events, 0 events recorded)
Number of events matching above criteria = 0
No diagnostic log entry exists.
hope this wl help you.
Vaibhav
jinglei yan
Frequent Visitor
Frequent Visitor
hi , I  have the same problem now . how you solve it about the x4648-rj45 with orange  , can you tell me , thank you very much .
Can you post the outputs of ;
show ver
show module
show diagnostic result module all
