WS-X45-Sup8E with SSO
networks PTC
Hi experts,
we're going to plan to implement Sup8E in 4510R+E.
Could you confirm if all the 8 uplink ports in every Sup8E can be used after SSO enabled? or will have the ports limitation like Sup7E?
Simon
Reza Sharifi
have a look at table-2 in this link:
You can use 2 10Gig ports from each sup when you have dual sup (SSO)
http://www.cisco.com/c/en/us/products/collateral/switches/catalyst-4500-series-switches/data_sheet_c78-728191.htmlv
Reza Sharifi
