Can't Ping Devices
mharing01
Cisco Switch
- vlan 1 "management" - ip address 192.168.1.254 255.255.255.0
- vlan 2 "students"
- vlan 3 "staff"
- default gateway 192.168.1.1
- int fa 0/1 - switchport mode access - switchport access vlan 1
- int fa 0/2 - switchport mode access - switchport access vlan 2
- int fa 0/3 - switchport mode access - switchport access vlan 3 (Device 2)
- int fa 0/23 - switchport mode trunk - switchport trunk allowed vlan all - switchport trunk native vlan 1 (Aruba Switch to ge 0/0/23)
- int fa 0/24 - switchport mode trunk - switchport trunk allowed vlan all - switchport trunk native vlan 1 (Cisco Router)
Cisco Router
- vlan 2 "students"
- vlan 3 "staff"
- int fa 0/0 - no shutdown
- int fa 0/0.1 - ip address 192.168.1.1 255.255.255.0 - Encapsulation Dot1q 1 native
- int fa 0/0.2 - ip address 192.168.2.1 255.255.255.0 - Encapsulation Dot1q 2
- int fa 0/0.3 - ip address 192.168.3.1 255.255.255.0 - Encapsulation Dot1q 3
Aruba Switch
- vlan 1 "management" - ip address 192.168.1.253 255.255.255.0
- vlan 2 "students"
- vlan 3 "staff"
- ip default-gateway 192.168.1.1
- int ge 0/0/0 - switchport mode access - switchport access vlan 1
- int ge 0/0/1 - switchport mode access - switchport access vlan 2 (Device 1)
- int ge 0/0/2 - switchport mode access - switchport access vlan 3
- int ge 0/0/23 - switchport mode trunk - switchport trunk allowed vlan all - switchport trunk native vlan 1 (Cisco Switch to fa 0/23)
Device 1 is on VLAN 2 (192.168.2.25) - plugged into Aruba switch (port ge 0/0/1)
Device 2 is on VLAN 3 (192.168.3.25) - plugged into Cisco switch (port fa 0/3)
Pings:
- from device 1 I cannot ping device 2 or Aruba switch
- from device 1 I can ping all three router interfaces and cisco switch
- from device 2 I cannot ping device 1 or Aruba switch
- from deviec 2 I can ping all three router interfaces and cisco switch
Not sure why I can't ping from device 1 to device 2, device 2 to device 1 or from either device to Aruba switch?
your configuration is quit good. Even I try in pack tracer, both devices are pinging each other. you should check the default gateways of both devices and trunk between switches are well.
Kazim
