WS-X6148A-GE-TX problem on Catalyst - 6506E
micoogullari
Dear All,
we have a Catalyst 6506-E switch with Cisco IOS Software, s72033_rp Software (s72033_rp-IPSERVICESK9_WAN-VM), Version
12.2(33)SXH4, RELEASE SOFTWARE (fc1).
Recently we bought a  WS-X6148A-GE-TX  card and we installed the card to the chassis. the  6506-E looks like recognize the card but unfortunately the status shows Powerdown and Fw/Sw shows unknown ??
Mod      Ports      Card Type                                                            Model
  4        48            48-port 10/100/1000 RJ45 EtherModule                  WS-X6148A-GE-TX
Mod      MAC addresses                                 Hw         Fw                Sw                Status
4       c47d.4f9d.3b50 to c47d.4f9d.3b7f             4.0        Unknown      Unknown      PwrDown
any idea?
Thanks to all in advance for your kind support.
regards,
mico
13 Replies 13
jorge.calvo
The problem could be a incompatibility between the supervisor card used, the IOS version and its support for the GE module.
Hope the following chart with the minimum required supervisor/IOS helps.
Software support
With Supervisor Engine 2—12.1(19)E1
With Supervisor Engine 32—12.2(18)SXF
With Supervisor Engine 32 PISA—12.2(18)ZY
With Supervisor Engine 720—12.2(18)SXF
With Supervisor Engine 720 and WS-F6K-GE48-AF or WS-F6K48-AF PoE daughter cards—12.2(17d)SXB (WS-X6148-GE-TX only)
With Supervisor Engine 720-10GE—12.2(33)SXH
Catalyst OS:
WS-X6148-GE-TX—7.6(9)
WS-X6148A-GE-TX—8.4(1)
Regards.
Hi Jorge,
thank you for your kind reply.  we have  Supervisor Engine 720 10GE with IOS version  12.2(33)SXH4 installed.
How many modules are there on the switch. Is there enough power for all of them?
Please, see power requirements for this module.
Module current— 2.50A
Module power—105.00 W
AC-input power—131.25 W
AC heat dissipation—448.22 BTU/hour
DC-input power—141.13 W
DC heat dissipation—481.96 BTU/hour
Regards.
I have 4 modules  as listed below. could be power  issue as you mentioned. I will double check and let you know.
1                     24                     CEF720 24 port 1000mb SFP                                    WS-X6724-SFP
2                     24                     CEF720 24 port 1000mb SFP                                    WS-X6724-SFP
5                     5                          Supervisor Engine 720 10GE (Active)                     VS-S720-10G
mico
how many power supply is on the 6500? are they setup in redunant mode?
issue "show power redundancy-mode"
Hi Francisco,
thank you for your support.  on the 6500 we have two PS and they are redundant. here is the details about the  power.  I did not try to install then on different slot. I will do that too and i will update you about the result.
Thank to all for the support and assistance.
mico
system power redundancy mode = redundant
system power total =     5771.64 Watts (137.42 Amps @ 42V)
system power used =      1063.02 Watts (25.31 Amps @ 42V)
system power available = 4708.62 Watts (112.11 Amps @ 42V)
                        Power-Capacity PS-Fan Output Oper
PS   Type               Watts   A @42V Status Status State
1    WS-CAC-6000W       5771.64 137.42 OK     OK     on
2    WS-CAC-6000W       5771.64 137.42 OK     OK     on
                        Pwr-Allocated  Oper
Fan  Type               Watts   A @42V State
1    WS-C6506-E-FAN       98.70  2.35  OK
                        Pwr-Requested  Pwr-Allocated  Admin Oper
Slot Card-Type          Watts   A @42V Watts   A @42V State State
1    WS-X6724-SFP        162.96  3.88   162.96  3.88  on    on
2    WS-X6724-SFP        125.16  2.98   125.16  2.98  on    on
4    WS-X6148A-GE-TX     105.00  2.50     -     -     on    off (not supported)
5    VS-S720-10G         338.10  8.05   338.10  8.05  on    on
6    (Redundant Sup)       -     -      338.10  8.05  -     -
Can you post a "sh env/sh env power/sh power" (sorry i can never remember which one !!).
Also you are not running VSS are you ?
Jon
"show envir status module 4"
Francisco
Hi Jon,
thank you for your reply and guidance.
yes we are running VSS.
we installed the cards ot the two 6506-E  and we are facing the mentioned problem.
You cannot run this card in a VSS system. You need all WS-X67xx modules in a VSS system, see the VSS Q&A for details of supported modules -
VSS Q&A
Jon
Yes,
That module is not compatible with VSS. See my VSS hardware details to have an idea:
2 x C6506-E running IOS 12.2-33SXI
SUP720 10GE
WS-X6748-GE-TX module
2 x WS-CAC-3000W power supplies.
Regards.
francisco_1
Level 7
Level 7
Jon,
Good you asked the question about VSS. Yep the 6148 will not work...
Francisco
