WS-X6408A-GBIC problem
jj-zhou
Hi netpro:
I find that module WS-X6408A-GBIC do not work . when I reboot the s6509 ,the system display "
LC_DNLD_START: Error - SCP send fail
2007 Sep 20 13:42:04 %SYS-5-MOD_RMVDNLDSTOP:Download terminated for module 3. Module removed
2007 Sep 20 13:42:04 %SYS-5-MOD_DNLDFAIL:Download failed for module 3 ".
The command "sh modeule 3" display :
6509A> (enable) sh mod 3
Mod Slot Ports Module-Type Model Sub Status
3 3 8 1000BaseX Ethernet WS-X6408A-GBIC no other
Mod Module-Name Serial-Num
3 SAL06478NLR
Mod MAC-Address(es) Hw Fw Sw
3 00-01-97-23-6a-44 to 00-01-97-23-6a-4b 1.3 5.4(2) 0.0
Please help me deduce what problem the module is .
Thank you
glen.grant
I think it means the card cannot talk to the supervisor and download the code needed . Most cases this means the card is bad and needs to be replaced .
arburt
a Status = other means SCP communication does not work
1. try to reseat the module
2. share 'show test mod 3','show scp mod 3' and 'show scp failcnt' results
regards,
arburt
please pose the ios information.
Hi arburt:
my 6509 catos is 7.31,and there is no command about "show scp ".
show test mode 3:
6509A> (enable) sh test 3
Diagnostic mode: complete (mode at next reset: complete)
Module 3 : 8-port 1000BaseX Ethernet
Line Card Status for Module 3 : PASS
Port Status :
Ports 1 2 3 4 5 6 7 8
GBIC Status :
N N N N N N N N
Line Card Diag Status for Module 3 (. = Pass, F = Fail, N = N/A)
Syndiags will run on Module 3 in a moment.
6509A#sh scp ?
accounting Show SCP accounting
counters Show SCP counters
linecards Display CWAN linecards in chassis
mcast Show SCP Multicast information
process Show SCP process information
status Show status of local SCP server
when I enter into session 15 (msfc card)
6509A#sh scp status
Rx 8124, Tx 7115, Sap 13
Id Channel name current/peak/retry/total time(queue/process)
0 SCP async: TCAM MGR 0/ 15/ 0/ 28 332/ 420/ 4
1 SCP async: Fake MCA 0/ 0/ 0/ 0 0/ 0/ 0
2 SCP async: RUN_CONF 0/ 1/ 0/ 1 0/ 0/ 0
3 SCP async: [cfg] l3 0/ 4/ 0/ 9 68/ 116/ 0
4 SCP async: [mls] l3 0/ 55/ 0/ 505 56/ 228/ 4
5 SCP async: HA SRM S 0/ 0/ 0/ 0 0/ 0/ 0
6 SCP async: HA SRM M 0/ 0/ 0/ 0 0/ 0/ 0
7 SCP Unsolicit:0 0/ 3/ 0/ 366 0/ 0/ 104
8 SCP async: Draco-NM 0/ 0/ 0/ 0 0/ 0/ 0
9 SCP async: NMP 0/ 1/ 0/ 2 0/ 348/ 0
10 SCP async: constall 0/ 0/ 0/ 0 0/ 0/ 0
