08-06-2013 10:46 AM - edited 03-07-2019 02:46 PM
I have a really strange problem. I'm trying to setup a 10G 802.1q trunk port between 2 buildings and I'm getting a strange packet loss issue. The connections will start fine and then just stop. Router 1 will send packets to router 2 that are received but the packets from router 1 will start disappearing on the way to router 2. I've even setup a tftp-server on both routers and copied files between them. The same results. The problem lies somewhere between the 2 routers.
This only occurs on the TE ports. The GE ports I've been using are fine. I've also put a light meter on the fiber and it checks out. It's single mode with LR transceivers. The run is about 800 feet. My equipment is OLD so direct TAC support is unavailable.
Hardware
Building 1:
Mod Ports Card Type Model Serial No.
1 16 16 port 1000mb GBIC ethernet WS-X6416-GBIC
2 48 48-port 10/100 mb RJ45 WS-X6148-RJ-45
3 48 48-port 10/100 mb RJ45 WS-X6148-RJ-45
4 48 48-port 10/100 mb RJ45 WS-X6148-RJ-45
5 48 48-port 10/100 mb RJ45 WS-X6148-RJ-45
6 48 48-port 10/100 mb RJ45 WS-X6148-RJ-45
7 2 Supervisor Engine 720 (Active) WS-SUP720-BASE
8 2 Supervisor Engine 720 (Hot) WS-SUP720-BASE
9 48 48-port 10/100 mb RJ45 WS-X6148-RJ-45
10 48 48-port 10/100 mb RJ45 WS-X6148-RJ-45
11 4 CEF720 4 port 10-Gigabit Ethernet WS-X6704-10GE
Mod MAC addresses Hw Fw Sw Status
1 0005.740c.59f8 to 0005.740c.5a07 2.0 5.4(2) 12.2(33)SXI9 Ok
2 000c.ce27.3f18 to 000c.ce27.3f47 1.2 5.4(2) 12.2(33)SXI9 Ok
3 0012.4304.5e90 to 0012.4304.5ebf 3.1 5.4(2) 12.2(33)SXI9 Ok
4 0012.0182.2228 to 0012.0182.2257 3.1 5.4(2) 12.2(33)SXI9 Ok
5 0015.c667.a944 to 0015.c667.a973 5.0 8.3(1) 12.2(33)SXI9 Ok
6 000c.ce27.41b8 to 000c.ce27.41e7 1.2 5.4(2) 12.2(33)SXI9 Ok
7 0013.7f0d.a5c0 to 0013.7f0d.a5c3 3.3 8.1(3) 12.2(33)SXI9 Ok
8 0011.92e6.fa08 to 0011.92e6.fa0b 3.1 8.1(3) 12.2(33)SXI9 Ok
9 0016.9d53.aeb0 to 0016.9d53.aedf 5.1 8.3(1) 12.2(33)SXI9 Ok
10 0012.016a.f6e8 to 0012.016a.f717 3.1 5.4(2) 12.2(33)SXI9 Ok
11 8843.e1aa.b978 to 8843.e1aa.b97b 3.1 12.2(14r)S5 12.2(33)SXI9 Ok
Mod Sub-Module Model Serial Hw Status
7 Policy Feature Card 3 WS-F6K-PFC3A 2.5 Ok
7 MSFC3 Daughterboard WS-SUP720 2.5 Ok
8 Policy Feature Card 3 WS-F6K-PFC3A 2.4 Ok
8 MSFC3 Daughterboard WS-SUP720 2.3 Ok
11 Distributed Forwarding Card WS-F6700-DFC3A 2.2 Ok
Building 2:
1 48 48 port 10/100 mb RJ21 Enhanced QoS WS-X6248A-TEL
2 48 48 port 10/100 mb RJ21 Enhanced QoS WS-X6248A-TEL
3 48 48 port 10/100 mb RJ21 Enhanced QoS WS-X6248A-TEL
4 48 48 port 10/100 mb RJ-21 ethernet WS-X6248-TEL
5 2 Supervisor Engine 720 (Active) WS-SUP720-BASE
6 2 Supervisor Engine 720 (Hot) WS-SUP720-BASE
7 4 CEF720 4 port 10-Gigabit Ethernet WS-X6704-10GE
8 16 16 port 1000mb GBIC ethernet WS-X6416-GBIC
9 96 96-port 10/100 Mbps RJ45 WS-X6196-21AF
1 0030.b63c.df90 to 0030.b63c.dfbf 1.0 5.1(1)CSX 8.5(0.46)RFW Ok
2 0005.9a8a.9118 to 0005.9a8a.9147 2.0 5.4(2) 8.5(0.46)RFW Ok
3 0001.9754.6d80 to 0001.9754.6daf 1.0 5.1(1)CSX 8.5(0.46)RFW Ok
4 00d0.d331.f118 to 00d0.d331.f147 1.0 4.2(0.24)VAI 8.5(0.46)RFW Ok
5 0011.21a1.587c to 0011.21a1.587f 3.2 8.1(3) 12.2(18)SXF1 Ok
6 0013.7f0a.7004 to 0013.7f0a.7007 3.3 8.1(3) 12.2(18)SXF1 Ok
7 0019.aaf1.dcf8 to 0019.aaf1.dcfb 2.5 12.2(18r)S1 12.2(18)SXF1 Ok
8 0009.b794.1400 to 0009.b794.140f 2.3 5.4(2) 8.5(0.46)RFW Ok
9 0019.306d.d796 to 0019.306d.d7f5 1.4 8.2(2) 8.5(0.46)RFW Ok
5 Policy Feature Card 3 WS-F6K-PFC3A 2.4 Ok
5 MSFC3 Daughterboard WS-SUP720 2.4 Ok
6 Policy Feature Card 3 WS-F6K-PFC3A 2.5 Ok
6 MSFC3 Daughterboard WS-SUP720 2.5 Ok
7 Distributed Forwarding Card WS-F6700-DFC3A 2.2 Ok
9 IEEE Voice Daughter Card WS-F6K-FE48X2-AF 1.4 Ok
Below is the relavant configuration from both routers. I only pasted 1 copy as its identical on both except for slot differences on the ports. The only thing I do to cause the packet loss is move the fiber from the GE ports to the TE ports and everything falls apart. Moving it back to the GE ports puts everything back to normal.
spanning-tree mode rapid-pvst
spanning-tree portfast default
interface GigabitEthernet5/1
switchport
switchport mode trunk
mtu 9216
no ip address
mls qos trust dscp
end
interface TenGigabitEthernet7/3
switchport
switchport trunk allowed vlan 1-999
mtu 9216
no ip address
shutdown
mls qos trust dscp
end
I'm excluding vlan 1000 on the TE port since it has storage server traffic on it. The other vlans can handle some packet loss for short periods while I'm testing. The storage servers cannot.
The really strange thing about this is I get ZERO error counters.
Router 1:
show int
TenGigabitEthernet11/3 is down, line protocol is down (notconnect)
Hardware is C6k 10000Mb 802.3, address is 8843.e1aa.b97a (bia 8843.e1aa.b97a)
MTU 9216 bytes, BW 10000000 Kbit, DLY 10 usec,
reliability 255/255, txload 0/255, rxload 0/255
Keepalive set (10 sec)
Full-duplex, 10Gb/s, media type is 10Gbase-LR
input flow-control is off, output flow-control is off
Last input 00:39:30, output 00:39:30, output hang never
Last clearing of "show interface" counters 11w1d
Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/40 (size/max)
1756250870 packets input, 276893128198 bytes, 0 no buffer
Received 4652610 broadcasts (2814099 multicasts)
0 watchdog, 0 multicast, 0 pause input
2287076473 packets output, 1940759519804 bytes, 0 underruns
0 output errors, 0 collisions, 1 interface resets
Show fabric errors
Module errors:
slot channel crc hbeat sync DDR sync
7 0 0 0 0 0
8 0 0 0 0 0
11 0 0 0 0 0
11 1 0 0 0 0
Fabric errors:
slot channel sync buffer timeout
7 0 0 0 0
8 0 0 0 0
11 0 0 0 0
11 1 0 0 0
Router 2:
Show int
TenGigabitEthernet7/3 is administratively down, line protocol is down (disabled)
Hardware is C6k 10000Mb 802.3, address is 0019.aaf1.dcfa (bia 0019.aaf1.dcfa)
Full-duplex, 10Gb/s
Last input 00:37:27, output 00:36:55, output hang never
Last clearing of "show interface" counters 12w2d
2287095723 packets input, 1940873532153 bytes, 0 no buffer
Received 312018 broadcasts (298729 multicasts)
1756240845 packets output, 276904112065 bytes, 0 underruns
Show fabric errors
Module errors:
5 0 0 0 0 0
6 0 0 0 0 0
7 0 0 0 0 0
7 1 0 0 0 0
Fabric errors:
5 0 0 0 0
6 0 0 0 0
7 0 0 0 0
7 1 0 0 0
Hopefully someone can help me shed some light on this as its the strangest problem I've ever seen.
Dave
