WS-X6704-10GE w/ DFC3C in 6513 PwrDown
robertjuric
I just added a X6704 card to our 6513 switch, and it is not working correctly. We are running 12.2(33)SXI5
switch#sh module 2
Mod Ports Card Type                              Model              Serial No.
  2    4  CEF720 4 port 10-Gigabit Ethernet      WS-X6704-10GE      SAL1543TU2L
Mod MAC addresses                       Hw    Fw           Sw           Status
  2  ccef.48cd.9308 to ccef.48cd.930b   3.2   Unknown      Unknown      PwrDown
Mod  Sub-Module                  Model              Serial       Hw     Status
  2  Distributed Forwarding Card WS-F6700-DFC3C     SAL1552ZGTZ  1.5    PwrDown
Mod  Online Diag Status
  2  Not Applicable
From all the other posts I could find I couldn't find anything that would allude to the source of our problem. Any help would be greatly appreciated.
7 Replies 7
Aninda Chatterjee
Hi Robert,
Could you post the output of:
1. show module
2. show platform hardware pfc mode
3. show power
Thanks.
switch#show module
  1   16  16 port 1000mb GBIC ethernet           WS-X6416-GBIC      SAD0523027U
  3    6  Firewall Module                        WS-SVC-FWM-1       SAD07500062
  4    6  Firewall Module                        WS-SVC-FWM-1       SAD083501DP
  5    8  8 port 1000mb ethernet                 WS-X6408-GBIC      SAD03341109
  6   48  48 port 10/100/1000mb EtherModule      WS-X6148-GE-TX     SAL09264JAC
  7    2  Supervisor Engine 720 (Active)         WS-SUP720-3B       SAL11487XY4
  8    2  Supervisor Engine 720 (Hot)            WS-SUP720-3B       SAL114883YP
  9   16  SFM-capable 16 port 1000mb GBIC        WS-X6516A-GBIC     SAL1115LH72
10   48  48-port 10/100/1000 RJ45 EtherModule   WS-X6148A-GE-TX    SAL11509ZJA
11   48  48 port 10/100 mb RJ45                 WS-X6348-RJ-45     SAL05084YM3
12   48  48-port 10/100/1000 RJ45 EtherModule   WS-X6148A-GE-TX    SAL11509WP2
  1  0002.7ef9.a1d2 to 0002.7ef9.a1e1   1.2   5.4(2)       12.2(33)SXI5 Ok
  3  0003.fead.626a to 0003.fead.6271   2.0   7.2(1)       4.1(1)       Ok
  4  0001.c9df.7b88 to 0001.c9df.7b8f   3.0   7.2(1)       4.1(1)       Ok
  5  0030.8066.55c0 to 0030.8066.55c7   2.3   4.2(0.24)VAI 12.2(33)SXI5 Ok
  6  0009.125d.3b00 to 0009.125d.3b2f   1.1   7.2(1)       12.2(33)SXI5 Ok
  7  0019.e7d4.1df0 to 0019.e7d4.1df3   5.6   8.5(2)       12.2(33)SXI5 Ok
  8  0016.c848.2404 to 0016.c848.2407   5.6   8.5(2)       12.2(33)SXI5 Ok
  9  001b.5329.d650 to 001b.5329.d65f   4.5   7.2(1)       12.2(33)SXI5 Ok
10  001e.7a84.0190 to 001e.7a84.01bf   1.6   8.4(1)       12.2(33)SXI5 Ok
11  0004.de61.e5f0 to 0004.de61.e61f   2.0   5.4(2)       12.2(33)SXI5 Ok
12  001e.7a83.f830 to 001e.7a83.f85f   1.6   8.4(1)       12.2(33)SXI5 Ok
  7  Policy Feature Card 3       WS-F6K-PFC3B       SAL11488B80  2.3    Ok
  7  MSFC3 Daughterboard         WS-SUP720          SAL11488BDV  3.1    Ok
  8  Policy Feature Card 3       WS-F6K-PFC3B       SAL11487WWH  2.3    Ok
  8  MSFC3 Daughterboard         WS-SUP720          SAL11488308  3.1    Ok
  1  Pass
  2  Not Applicable
  3  Pass
  4  Pass
  5  Pass
  6  Pass
  7  Pass
  8  Pass
  9  Pass
10  Pass
11  Pass
12  Pass
switch#show platform hardware pfc mode
PFC operating mode : PFC3B
switch#show power
system power redundancy mode = redundant
system power total =     2771.16 Watts (65.98 Amps @ 42V)
system power used =      1974.42 Watts (47.01 Amps @ 42V)
system power available =  796.74 Watts (18.97 Amps @ 42V)
                        Power-Capacity PS-Fan Output Oper
PS   Type               Watts   A @42V Status Status State
1    WS-CAC-3000W       2771.16 65.98  OK     OK     on
2    WS-CAC-3000W       2771.16 65.98  OK     OK     on
                        Pwr-Allocated  Oper
Fan  Type               Watts   A @42V State
1    WS-C6K-13SLT-FAN2   298.20  7.10  OK
                        Pwr-Requested  Pwr-Allocated  Admin Oper
Slot Card-Type          Watts   A @42V Watts   A @42V State State
1    WS-X6416-GBIC       118.02  2.81   118.02  2.81  on    on
2    WS-X6704-10GE       333.06  7.93     -     -     on    off (not supported)
3    WS-SVC-FWM-1        171.78  4.09   171.78  4.09  on    on
4    WS-SVC-FWM-1        171.78  4.09   171.78  4.09  on    on
5    WS-X6408-GBIC        84.00  2.00    84.00  2.00  on    on
6    WS-X6148-GE-TX      103.74  2.47   103.74  2.47  on    on
7    WS-SUP720-3B        282.24  6.72   282.24  6.72  on    on
8    WS-SUP720-3B        282.24  6.72   282.24  6.72  on    on
9    WS-X6516A-GBIC      152.04  3.62   152.04  3.62  on    on
10   WS-X6148A-GE-TX     105.00  2.50   105.00  2.50  on    on
11   WS-X6348-RJ-45      100.38  2.39   100.38  2.39  on    on
12   WS-X6148A-GE-TX     105.00  2.50   105.00  2.50  on    on
system auxiliary power mode = off
system auxiliary power redundancy operationally = non-redundant
system primary connector power limit =   5880.00 Watts (140.00 Amps @ 42V)
system auxiliary connector power limit = 0 Watt
system primary power used =              1974.42 Watts (47.01 Amps @ 42V)
system auxiliary power used =            0 Watt
Hi Robert,
I think the 6704-10GE requires dual fabric channels to function. Can you move this to another empty slot (any available slot between 9 and 13) and check if the module comes up?
In a 6513, only slots 9 through 13 have dual channel connections.
glen.grant
In a 13-slot chassis, WS-X6704-10GE is supported only in slots 9 through 13 and does not power up in other slots.
We had one other slot open on this box; the card is working great now. Thanks for the info guys.
Hi guys
  i have some problem related to ws-x6704-10ge,
1) Does it suuport 64 bit or not
2)May i used 9 port for data transfer
Afeter using ws-x6704-10ge i think it's not a effective...
please give your Advice..;-)
haung0001
WS-X6704-10GE w/ DFC3C in 6504-E PwrDown
