WS-X6708-10G-3CXL doesn't work on WS-C6506-E
inevalink
Beginner
Beginner
we can't start WS-X6708-10G-3CXL on WS-C6506-E
here is more info:
SW0#sh ver
Cisco IOS Software, s72033_rp Software (s72033_rp-ADVIPSERVICESK9_WAN-M), Version 12.2(33)SRA7, RELEASE SOFTWARE (fc2)
SW0#sh module
Mod Ports Card Type                              Model              Serial No.
1   24  CEF720 24 port 1000mb SFP              WS-X6724-SFP       SAL1206FBVM
2   48  SFM-capable 48 port 10/100/1000mb RJ45 WS-X6548-GE-TX     SAL0917A0MC
3   24  CEF720 24 port 1000mb SFP              WS-X6724-SFP       SAL1232ZH7F
4    8  FRU type (0x6003, 0x3F8(1016))         WS-X6708-10GE      SAL1625EX75
6    2  Supervisor Engine 720 (Active)         WS-SUP720-3B       SAL092756DS
Mod MAC addresses                       Hw    Fw           Sw           Status
1  001e.f783.9bf4 to 001e.f783.9c0b   3.1   12.2(18r)S1  12.2(33)SRA7 Ok
2  0013.c424.34b8 to 0013.c424.34e7  10.1   7.2(1)       8.6(0.259)CA Ok
3  0022.55f4.04c0 to 0022.55f4.04d7   3.2   12.2(18r)S1  12.2(33)SRA7 Ok
4  442b.034f.6f98 to 442b.034f.6f9f   3.5   Unknown      Unknown      PwrDown
6  0012.dae4.7f10 to 0012.dae4.7f13   4.4   8.1(3)       12.2(33)SRA7 Ok
Mod  Sub-Module                  Model              Serial       Hw     Status
1  Centralized Forwarding Card WS-F6700-CFC       SAL1205F0ES  4.0    Ok
3  Centralized Forwarding Card WS-F6700-CFC       SAL1226V4AS  4.1    Ok
4  Distributed Forwarding Card WS-F6700-DFC3CXL   SAL1626FA3U  1.7    PwrDown
6  Policy Feature Card 3       WS-F6K-PFC3B       SAL092753DG  2.1    Ok
6  MSFC3 Daughterboard         WS-SUP720          SAL09253GB9  2.3    Ok
Mod  Online Diag Status
1  Pass
2  Pass
3  Pass
4  Not Applicable
6  Pass
we did try on conf t mode "power enable module 3" and it didn't work
Oct 28 15:01:06: %C6KPWR-SP-4-UNSUPPORTED: unsupported module in slot 4, power not allowed: Unknown Card Type.
Oct 28 15:01:56: %SYS-5-CONFIG_I: Configured from console by bill3 on vty0 (89.223.47.133)
Oct 28 15:03:36: %C6KPWR-SP-4-UNSUPPORTED: unsupported module in slot 4, power not allowed: Unknown Card Type.
SW0#sh power
system power redundancy mode = combined
system power total =     6325.20 Watts (150.60 Amps @ 42V)
system power used =      1038.66 Watts (24.73 Amps @ 42V)
system power available = 5286.54 Watts (125.87 Amps @ 42V)
                       Power-Capacity PS-Fan Output Oper
PS   Type               Watts   A @42V Status Status State
1    WS-CAC-4000W-INT   3795.12 90.36  OK     OK     on
2    WS-CAC-6000W       5771.64 137.42 OK     OK     on
                       Pwr-Allocated  Oper
Fan  Type               Watts   A @42V State
1    WS-C6506-E-FAN       98.70  2.35  OK
                       Pwr-Requested  Pwr-Allocated  Admin Oper
Slot Card-Type          Watts   A @42V Watts   A @42V State State
1    WS-X6724-SFP        125.16  2.98   125.16  2.98  on    on
2    WS-X6548-GE-TX      125.16  2.98   125.16  2.98  on    on
3    WS-X6724-SFP        125.16  2.98   125.16  2.98  on    on
4    WS-X6708-10GE       473.76 11.28     -     -     on    off (not supported)
5    (Redundant Sup)       -     -      282.24  6.72  -     -
6    WS-SUP720-3B        282.24  6.72   282.24  6.72  on    on
Reza Sharifi
Hall of Fame Master Hall of Fame Master
Hall of Fame Master
Can you move the module to a different slot and try again?
Also, you are running a very old version of IOS.  Try a later version of SXi or SXJ.
DFC3CXL cards require newer IOS.
tab 5 "Minimum Software Requirements for New Distributed Forwarding Cards" of
http://www.cisco.com/en/US/prod/collateral/iosswrel/ps8802/ps6970/ps6017/prod_bulletin0900aecd806afd81.html
WS-F6700-DFC3CXL
• Cisco IOS Software Release 12.2(18)SXF5 and later with Cisco Supervisor 720 3B if using with WS-X6708-10G-3CXL line card
• Cisco IOS Software Release 12.2(33)SXH and later with all the line cards mentioned above
So as Reza wrote you need to upgrade software.
Riccardo
Recognize Your Peers
