WS-X6708-10GE asic-1 temperature is high
d-mercado
I have WS-C6509-E with WS-X6708-10GE installed, i noticed that my asic-1  & 2 temperature is reaching to 65C. Can anyone give me some document what is the normal temparature for ASIC.
  module 8:
  module 8 power-output-fail: OK
  module 8 outlet temperature: 44C
  module 8 inlet temperature: 32C
  module 8 aux-1 temperature: 45C
  module 8 aux-2 temperature: 42C
  module 8 asic-1 temperature: 65C
  module 8 asic-2 temperature: 64C
  module 8 EARL outlet temperature: 36C
  module 8 EARL inlet temperature: 33C
WS-C6509-E-FAN
WS-C6509-E
WS-X6708-10GE
5 Replies 5
Nelson Galimba
Take a look at the out put of  "show idprom module 8 detail"
Specifically, take a look at the 'sensor auxiliary block' section, sensor No. 0 is for ASIC1 and No. 1 is for ASIC2.
The temperatures of the ASIC will operate up to 127C.
Hope that helps,
Nelson
Can you please provide the link you're getting this information from? I just need a reference so I can show the monitoring team. thanks
Thanks. That does help
oded-levi
I have ws-x6708-10ge.
The tempature of the asic -1 is 78C.
It is OK???
Oded,
Yes, this is OK. The temperature being measured there is inside the ASIC itself, and so we expect these to be much higher than the sensors that are on the baseboard.
Scott H
