Zone Based Firewall for IPSec - Virtual-Template1 - ASR1000
kasunrajapakse
Hi Guys,
I'm configuring a zone based firewall on my ASR1000.
My requirement is to block all the incoming traffic towards my router except IPSec traffic. Only remote IPsec peers can establish an IPSec with my ASR1000. Rest of the traffic should be blocked.
Any IPSEC traffic coming from the UNTRUST zone (via the Internet) should reach the ASR and go according to the Zone-Pairs.
However this doesn't seem to be working. Any help is highly appreciated.
class-map type inspect match-any L4-ipsec-class
match access-group name IPSECtraffic
ip access-list extended IPSECtraffic
permit esp any any
permit udp any any eq isakmp
permit ahp any any
permit udp any any eq non500-isakmp
class-map type inspect match-any L4-ip-class
match protocol icmp
match protocol tcp
match protocol udp
policy-map type inspect ALLOW-ALL
class type inspect L4-ipsec-class
pass
class type inspect L4-ip-class
inspect
class class-default
drop
interface Virtual-Template1 type tunnel
vrf forwarding Inside-VRF
ip unnumbered Loopback0
zone-member security IPSEC
no logging event link-status
no snmp trap link-status
tunnel source Loopback0
tunnel mode ipsec ipv4
tunnel vrf FVRF
tunnel protection ipsec profile btopcpe_vti
end
interface Loopback0
vrf forwarding FVRF
ip address 300.300.300.300 255.255.255.255
end
zone-pair security IPSEC_to_UNTRUST source IPSEC destination UNTRUST
service-policy type inspect ALLOW-ALL
zone-pair security UNTRUST_to_IPSEC source UNTRUST destination IPSEC
zone-pair security UNTRUST_to_default source UNTRUST destination default
zone-pair security default_to_UNTRUST source default destination UNTRUST
interface TenGigabitEthernet0/0/0
description Internet Link
vrf forwarding FVRF
ip address 400.400.400.400 255.255.255.254
ip nat outside
zone-member security UNTRUST
end
11 Replies 11
@kasunrajapakse
For the IPSec terminating on the untrust interface you'd use the "self" zone not default.
zone-pair security UNTRUST_to_default source UNTRUST destination self
zone-pair security default_to_UNTRUST source self destination UNTRUST
kasunrajapakse
Hello @Rob Ingram
Thank you for the feedback.
But it doesn't allow me to allocate the Virtual-Template1 in "zone-member security self"
ASR(config-if)#interface Virtual-Template1
ASR(config-if)#zone-member security self
% self zone is system defined. Interface attachment/detachment not allowed
ASR(config-if)#
zone-member security IPSEC  <<<<<<<<<<<<<<<<< This is the current Zone for the Virtual-Template1
tunnel vrf FVRF
end
Any idea??
That's not what I said. You need to modify the zone-pair as in the example I provided.
kasunrajapakse
Hi @Rob Ingram
Thank you . I have done the following. No joy
Am I missing something here?
zone-pair security UNTRUST_to_self source UNTRUST destination self
zone-pair security self_to_UNTRUST source self destination UNTRUST
kasunrajapakse
I have configured the following zone-pairs - hoping at least one of them would allow the IPSec traffic in.
Still no luck
zone-pair security IPSEC_to_self source IPSEC destination self
zone-pair security self_to_IPSEC source self destination IPSEC
make the change marked in bold to your policy map:
pass
--> inspect
class class-default
drop
Hi @Georg Pauwen @Rob Ingram
This is what I have configured now. My final config
My question is - How can traffic from "UNTRUST" come to "self" or inside the network without any policies?
I can establish the IPSec and traffic flows even without the following zone pairs in place.
I was under the impression that the above two pairs controls what' comes from the internet.
But IPSec works even without the above zone pairs. I think this is a possibly security risk.
Can you please help?
permit esp any any
permit ahp any any
match protocol icmp
match protocol tcp
match protocol udp
pass
inspect
class class-default
drop
ip access-list extended Inbound_IPSec_Traffic
permit esp any any
permit ahp any any
class-map type inspect match-any Inbound_IPSec_Traffic-class
match access-group name Inbound_IPSec_Traffic
class-map type inspect match-any Inbound_IPTraffic-class
match protocol icmp
match protocol tcp
match protocol udp
policy-map type inspect Inbound_IPsec_IPTraffic-policy
class type inspect Inbound_IPSec_Traffic-class
pass
class type inspect Inbound_IPTraffic-class
inspect
class class-default
drop
vrf forwarding trust
tunnel vrf FVRF
end
interface Loopback0
vrf forwarding FVRF
ip address <IPSEC IP> 255.255.255.255
end
description Uplink To Internet
vrf forwarding FVRF
ip address <WAN IP> 255.255.255.254
ip nat outside
ip access-group iACL in
end
interface Port-channel1.1760
encapsulation dot1Q 1760
ip address 10.0.22.1 255.255.255.0
zone-member security PO1760
end
zone-pair security UNTRUST_to_self source UNTRUST destination self >>> IPSec works without this pair
service-policy type inspect Inbound_IPsec_IPTraffic-policy
zone-pair security self_to_UNTRUST source self destination UNTRUST >>> IPSec works without this pair
zone-pair security IPSEC_to_PO1760 source IPSEC destination PO1760
zone-pair security PO1760_to_IPSEC source PO1760 destination IPSEC
I think the Loopback needs to be in the same security zone as the virtual template. Other than that the config looks good.
interface Loopback0
vrf forwarding FVRF
--> zone-member security IPSEC
end
Hi @Georg Pauwen
Thank you for the reply. But in my situation, the Virtual Template and the Loopback are in 2 different VRFs.
So it doesn't let me use the same security zone in multiple VRFs.
The reason why my Loopback has "vrf forwarding FVRF" is because it contains a public IP and I don't want my internal routing table to mixed with it.
Hope this is of help.
tunnel vrf FVRF
end
interface Loopback0
vrf forwarding FVRF
end
then create a second loopback for use with the virtual template ip unnumbered, and put that in the same zone as the virtual template.
kasunrajapakse
Thank you everyone.
The above config I had works (I had to reboot the ASR) that fixed all my issues.
