2 Telepresence Questions
bimckenz
I have a few questions in which I'm having trouble finding answers.
1) Wanted to verify that the c20 can natively do multipoint conferencing (up to 3) without the use of an MCU
2) Can you connect a projector to the c20?
3) Can you connect your laptop to the c20 for presentations?
Thank You in advance
Paul Woelfel
Level 4
Level 4
1) no, it can't. Alternatively have a look at the SX20 , it supports Multipoint up to 448p. If you want HD multipoint you'll need a C60
2) if the projector has an HDMI Input, it can be connected
3) yes, VGA or DVI an Audio.
Regards, Paul
Teck Chye Tang
the C20 has 2 hdmi output. If you want to use it as a dual monitor mode, then you need to have an dual screen option key.
You can also use a hdmi to dvi cable and connect to the projector if the projector has a dvi-i or dvi-d input. But be careful of the distance run else you might need to use extenders.
