adding new contact to SX20 via web?
MehmetKaya
Hi All,
We can adding new phone to Cisco Telepresence SX20 via Remote Control but not able to find via Web interface. There is a just phonebook server. But is not suitable. Do you have any way to adding new contact to SX20 via web interface.
2 Accepted Solutions
mubakhta
Level 4
Level 4
Hi Mehmet,
Currently adding contacts to phonebooks is not supported using the Web GUI. It is only supported using the remote control, Touch Panel & API.
Mubashshir Akhtar
Thanks Mubashshir Akhtar
amehla
Hi Mehmet,
As per the Mubashshir information, you can only add phonebook using remote control, touch panel and API.
it is currently not supported from GUI.
in the GUI, phonebook server 1, you can provision your device to fetch corporate phonebook from TMS.
however you can use below command to add local phonebook using API:
  • •1.       To add entry into the local phonebook:
Xcommand phonebook contact add name: Amit number: 10.1.1.1 protocol: h323
  • •2      To search the local phonebook or to see all the contacts in the local phonebook:
xCommand Phonebook Search PhonebookType: local
  • •3.       To delete a local phonebook entry:
Xcommand phonebook contact delete contactid: localcontactid-1
You can find the localcontactid of the particular contact by search phonebook with the xCommand Phonebook Search PhonebookType: local
mubakhta
Level 4
Level 4
Hi Mehmet,
Mubashshir Akhtar
amehla
Hi Mehmet,
