Alarm fan MCU 5320
Phong Tran
Hi All.
I have MCU 5320 is warning fan the fan out of spec.
MCU 5320.pngPlease support us to resolve this issue for our customer.
Tks.
Rishabh Gupta
Hi @Phong Tran ,
Try power cycle of the MCU and see if the status becomes OK. Otherwise open a TAC case with
Event and Diagnostic logs from the MCU to check if it requires replacement.
-Hope this helps !
Rishabh Gupta.
Rate the response & mark as a solution if found appropriate.
In addition to what Rishabh [+5] has said, u can also connect console to MCU and look for Keyword FAN in the captured logs after u power off and ON the MCU.
https://www.cisco.com/c/en/us/td/docs/telepresence/infrastructure/articles/cisco_telepresence_connect_console_port_kb_6.html
you should get message as below
HEALTH_MONITOR : Info : fan speed test successful
regds,
aman
Hi @Rishabh Gupta
I restarted the MCU, it OK. Thank for your support.
