Showing results forĀ
Search instead forĀ
Did you mean:Ā
Anyone wall-mounting a Touch 10 panel?
Shawn Jones
All-
We have a customer that would like them mounted in a secure mount, with tilting capability.
Is anyone doing this, and if so, how?
Are you able to remove the kick-stand on the back without too much trouble?
Thanks in advance.
SJ
23 Replies 23
jhayford1
The Kickstand removal is kind of a PITA but it can be done.  remove the 2 rubber feet and expose 2 screws. remove themput something smaller thru the screw hole and push the front glass out just enough to slip a credit card between the glass and the back cover.  run the credit card ( or 2 ) around the perimeter of the housing and the back cover will eventually snap off.  2 screws on the hinges is what holds the stand on.  Congratulations, I'm sure you just voided the warranty but you got the stand off!  Back cover snaps back on pretty easily.
Yes, but the mount we are going to use does not require a removal of the stand. :)
Shawn Jones
Contact a sales person at OneVision Solutions (972 714-0540) for a quote.
The touch panel fits without removal of the tilt stand. Four screws on the front allow for removal of the front plate containing the panel. The buttons on the front are accessible as well.
Brandon Rebbe
Website just went live, and mounts are available for order:
www.touch10mount.com
A five gang backbox to mount it? Does it come with it, or do you have to find it on your own?
chaywoo00
For anyone still looking, i have found two.
https://roomready.com/products/touch-10-wall-mount
https://avteq.net/product/c10-wm/
There is a company in Australia that is making Touch 10 Wall Mounts and Navigator compatible Wall Mounts. They ship worldwide. They are easy to install and look great.
You can buy them from their web store.
www.custommounts.com.au
or if you need to buy bulk contact them by email and you can get a discount.
Matt
