API command for Log Output
Mahesh Kumar
What is command to see the live log output using SSH api command via root, please find the below example.
2016.77 VIDEOLC-0 I: VLC_readySignalSourceEvent port:HDMI 1: no signal
2016.78 VIDEOLC-0 I: Received SourceFormatEvent from video link 16 (0x0@0, unknown type, error detected) in ready state
2016.78 MC I: LocalVideoInputGateImpl::setIncomingModeReport(ig=1,p=1)  [Video (0): vid-off 0x0@0.0  0k ]
2016.78 MC I: LocalVideoInputGateImpl::recalcIncomingMode(ig=1) res=0x0@0 q=Motion t60=921600 p=Normal
2016.79 MC I: LocalVideoInputGateImpl::recalcIncomingMode(ig=1) res=0x0@0 q=Motion t60=921600 p=Normal
2017.09 MediaStreamController I: MV::getVCSetting getOutputPortStatus initialized 1
2017.09 MediaStreamController I: MV::getVCSetting localHwCookieHint_ 16 w 720 h 480
2017.09 MediaStreamController I: MV::getVCSetting localHwCookieHint_ 0 w 1280 h 720
2017.10 MediaStreamController I: MV::getVCSetting localHwCookieHint_ 8 w 1024 h 768
2040.06 VIDEOLC-0 I: VLC_readySignalSourceEvent port:HDMI 1: have signal
Thanks in Advance
Mahesh Kumar
Dharmesh Nandoria
Hi Mahesh,
use commnad : "log output on" from admin login .
Kind regards,
Dharmmesh
6 Replies 6
Dharmesh Nandoria
Hi Mahesh,
Kind regards,
Dharmmesh
Dear Dharmesh,
          Really appreciate your quick response and for what echo ON and OFF command used in this scenario, does this makes any changes.
Sincerely,
Mahesh Kumar
What do you refer to as "echo"?
The log command parameters (TC6) work like this:
log output
Unknown command or wrong number of arguments
usage: log COMMAND [PARAMETER]...
Commands to control message production:
  ctx [CTX]+ debug N          Enable debug level N (1..9) for the context CTX
Other commands:
  list                    Lists registered contexts
  output          Output log to this console.
  help                    This help text
Parameter:
  LEVEL  - |info|notice|warning|error>
  CTX    - context name (as can be seen from "log list")
a reboot should also stop the logging
These two documents might be also interesting for you:
https://supportforums.cisco.com/docs/DOC-29766
https://supportforums.cisco.com/docs/DOC-15643
Hi Dharmesh,
          How to get only video or audio log output, because now if i say "log output on" it shows all the logs but if i want only any particular log. e.g. video, audio or network.
Sincerely,
Mahesh Kumar
Hi Mahesh,
If you want to look audio / video protocol, statistic, packet loss  for call ,use xstatus  It will have all detail.
Live log out put will provide detail for all logs , If you want to look specific log then log in from web interface  go to current log and down load specific log .
hth
Kind regards,
Dharmmesh
