bandwidth remote vs bandwidth interzone
jjia
Level 2
Level 2
The gatekeeper configured one local zone and one remote zone. We will use gatekeeper bandwidth CAC for controlling the number of calls from local zone to remote zone.
In this case, which bandwidth command I should use. Bandwidth remote or bandwidth interzone? Is there any difference between those two commands in this case?
JJ
stomasko
Level 4
Level 4
Interzones is between 2 zones on a gatekeeper, remote is bandwidth between 2 gatekeepers.
Take a look at this site for better detail and example.
http://www.cisco.com/en/US/tech/tk1077/technologies_configuration_example09186a0080094ac3.shtml
Hope this helps.
Steve
So in my case, I can also use bandwidth interzone command instead of bandwidth remote for controlling the number of calls between the local zone and the remote zone which is configured on a remote gatekeeper? see the following:
Gatekeeper
zone local localzone cisco.com
zone remote remotezone cisco.com 10.10.10.1 1719
bandwidth interzone localzone 128
no shutdown
Is it correct?
JJ
courtneyqisct06
Hope this helps.
Steve
Thanks for your explanation! I got more deep understanding about this part.
