BARCO Video walls
abdulkarim041
Level 2
Level 2
Dear All,
Can we integrate BARCO Video walls with Cisco Telepresense? If yes then how?
BR
Abdulkarim041
Jaime Valencia
A quick google search only shows a doc on an integration with VSOM, if you're familiar with those video walls, and are also familiar with Cisco TP, you should have a slight idea if an integration is possible between the different protocols both products support.
A quick glance at the products, they seem to be just video walls, no VoIP capabilities, but they *might* work if you add something like an SX10 to them.
java
if this helps, please rate
Jaime Valencia
java
Dear Jaime,
Thankss
