Cisco ccm 10.5 9951 phones no video
smartnet
Hi all,
trying to get two cisco 9951 phones to work with video... calling no problem... camera self view working... so camera no problem..
enabled everything op phone profiles..... can make calls but video even not trying to show something...
what can this be?????
thanks
2 Accepted Solutions
By any chance do you have the MTP required option checked on the phones??
java
if this helps, please rate
Disable it and try again
java
8 Replies 8
Jaime Valencia
Are they enabled for video??
Do you have enough BW in the locations for video calls?
java
Yes they are enabled in the phone and also in the settings on the ccm.... so Cisco Camera enabled and Video Capabilities enabled... also enough bandwith because it's just local....
system running on vmware and phones and vmware are connected by a switch...
something else i have may forgot to enable????
nobody any idea's?
java
Yep this is enabled on both phones...
java
will try It.. keep you posted :D
smartnet
Disbale MTP required working!! Thanks mate... ;)
