02-14-2014 06:52 AM - edited 03-18-2019 02:35 AM
my customer is looking for a small business Video Conference solution and i'm thinking about Cisco TelePresence SX20. My question is maybe too simple but i didn't found an answer over the web.
It's possible to setup a simple point-to-point Video Conference between 2 SX20 Endpoints without a Call Control Device (eg: CUCM, VCS) ? I'm planning to include Conferencing and Call Control Devices when the Endpoints will grow but, at the moment, i need only to have Audio\Video communications between 2 sites and try to reduce costs.
Thank you.
Roberto
02-14-2014 06:55 AM
Hi Roberto,
I advise you to post this question under Telepresence support community. This community is for Cisco WebEx Meetings Server and Cisco Unified MeetingPlace, and is not observed by Telepresence experts. Hence, you won't be able to get the answer you are looking for.
I hope this helps.
-Dejan
02-16-2014 03:14 PM
you will need something to register the device with and manage its addressing, i.e a CUCM (8.6) or TMS/VCS-E/VCS-C setup.
11-01-2016 07:01 AM
11-11-2016 02:16 PM
No problem you can have p2p call without a call control.
go to H.323 settings and change Callsetup mode from Gatekeeper to "Direct"
Gatekeeper address should be blank.
go to SIP settings and enable Listen port = "ON"
outbound port = off
Proxy address 1,2,3 = Blank
Reboot, now you can make Point to point calls between 2 endpoints with a call control, just using their IP addresses.
If you put the endpoint on Public IP address of behind a Static NAT. then you can also use to reach it by Public IP addresses.
if you have multisite option key installed, you can have a conference call upto 4 participants without requiring a conference bridge.
AMMAR
