10-23-2012 01:12 AM - edited 03-18-2019 12:01 AM
Hello!
Please post pictures of CTS-SX20-QS-WMK and CTS-QSC20-WMK.
Are they used for mounting the codecs or for the display screens?
Thanks in advance
10-23-2012 01:17 AM
Wall mount kits are for mouting the codec to the wall.
I have attached a photo of a sx20 with a wall mount kit ( the little bar in the top of the picture)
If you require a whole mount then I would recommend you to look at the profile series systems.
//Marius
10-23-2012 01:28 AM
Thanks Marius!
Am also ordering C20s so I want to know how the respective wallmount kit looks like.
10-23-2012 01:35 AM
Hi Kelvin.
I do not have any pictures of the wall mount it self, but it is illustrated in this pdf.
Just a recap, the wallmounts are there to
1. mount on the wall
2. hide cables going in and out from the codec.
//Marius
10-23-2012 09:31 AM
Hi Kelvin
link below is for the SX20 wall Mount Installation
BR
Dean
10-23-2012 11:01 PM
Thanks for the information.
So can I use remote control after I have installed the wall mount kits.
OR
The wall mount kits can only be used with touch pad controller.
10-24-2012 12:23 AM
Hi Kelivn.
There is a IR sensor on the codec, and there is a IR sensor in the camera.
So you can use the remote by pointing it at the camera ( which is pointing towards you anyway if you are in a call )
//Marius
04-20-2015 12:28 PM
Also be aware you can only use the remote if the touchpad is disconnected. as soon as you register the touchpad, the remote will not work
