C20 and SX20 Camera Cable
Leonardo Santana
Can i use the same cable from C20 Camera on the SX20 Camera?
Leonardo Santana
Leonardo Santana
*** Rate All Helpful Responses***
2 Accepted Solutions
Rafal Szeremeta
Hello Leonardo
SX 20 and C series use different connections for the cameras, so that is not possible using supplied cable.
Please check this link:
http://www.cisco.com/en/US/docs/telepresence/endpoint/camera/precisionhd/user_guide/precisionhd_1080p-720p_camera_user_guide.pdf
Thank you
Rafal
Hey Leonardo,
Yes the hdmi cable for the TV/Monitors are the same for each codec. The SX20 supports the Visca protocol which is why the camera cable is different. I however have connected a regular HDMI cable between the camera and codec without any issues as far as I can see, but always keep in mind to follow the guides and use the recommended cables.
Adam
Rafal Szeremeta
Hello Leonardo
Thank you
Rafal
Ok Thanks
And the hdmi cable that connects on tv is the same for C20 and SX20 correct?
Leonardo Santana
Leonardo Santana
Hey Leonardo,
Adam
Thanks Adam
I ll follow the Cisco recomendations.
Leonardo Santana
Leonardo Santana
