ā05-16-2013 01:29 PM - edited ā03-18-2019 01:07 AM
We have non-IP setup with a Cisco quickset C20 running ISDN lines using a Cisco ISDN link, when calling the polycom bridge we receive audio but no video is sent or received. I can make a direct call to another polycom and have no issues but when calling the bridge it seems that it connecting in secondary mode, or audio only. Any Ideas?
ā05-16-2013 11:44 PM
what type of ISDN gateway is it? have you look at the log files there?
when you said you make a direct call to Ply endpoint, did you mean direct IP call? not a Ply expert but doesn't MGC open up two connection lines/stream to each endpoint?
ā05-17-2013 10:18 AM
Is four bri lines connected to the Cisco ISDN telepresence link, by calling direct i mean direct dial to a polycom ISDN vtc without the need of the bridge. Not ply expert either not sure how the MGC works. But if it does openn two connections how do i configure the C20 to accept the connections. Currently i only get audio but no video.
Thanks for you help in advance.
ā05-18-2013 10:04 PM
As per detail given in the post , Calls are working with other polycom unit and not with MGC - This confirms configuration for C20 is ok .
You can disable encryption and test if call works .
codec :
xConfiguration Conference 1 Encryption Mode: Off
Link :
xConfiguration H320 Encryption: Off
Another problem i can see related to ISDN lines , Is your unit and MGC using ISDN lines from same service provider ? If not then may be issue with service provider network interop .
hth
Kind regards,
Dharmmesh
ā01-27-2015 08:17 AM
Hello i am having the same issue with an SX80/isdn link connecting to a Polycom MGC100. After a few calls we realized that the call worked if we disabled H.264.
